c32 occasionally smells like burning rubber
Old Jan 20, 2011 | 12:38 AM
Harvey2002c32's Avatar
c32 AMG
my 2002 c32 (108,000 miles) recently has briefly smelled like burning rubber inside. I checked around the wheels to make sure the brakes were not stuck on, and the smell is not coming from there. It seems to be coming through the vents. Upon opening the hood, the smell was there but only a little bit, and not as strong as it had been inside the car. The smell is not continuous and will go away after a few minutes. Additionally, the last couple times i have gotten to anout 9,000 miles before my 10,000 mile service A or B, it has told me to add 1 quart of engine oil. Could these be related? I figured, the requirement for a quart of oil not too long before my next scheduled oil change was not that terribly uncommon for a high performance car with over 100k miles on it. Now with this smell, I am starting to think maybe there is something wrong I need to have looked at?
Old Jan 20, 2011 | 12:39 AM
c32 AMG
has anyone had a problem like this before?
Old Jan 20, 2011 | 01:16 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
maybe check the sound damping by the rear axel. The sound dampening might have come loose and is burning from the heat of the exhaust. I would jack up the car and remove the underbody shield and just inspect the car. Or it could just be a plastic bag you ran over and is burning on the exhaust.
Old Jan 20, 2011 | 01:34 AM
MIKESV8's Avatar
Aston Martin V8 Vantage
+1. if you don't notice anything different AT ALL besides that i think you shoud be fine. i recommend changing the cabin filter though
Old Jan 20, 2011 | 01:57 AM
JUAN CASAUS's Avatar
2005 E55 AMG
Also you should make sure that your pulleys and serpentine belt is good
Old Jan 20, 2011 | 06:48 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
That happens pretty often, too - in fact, I had it happen with my C230. Against all odds, a plastic bag managed to be swept up underneath the car, wrap itself around the header, and start to melt/burn. Not pleasant.
The only thing I'd mention, is that IMHO burning plastic smells different from burning rubber, although close I guess. Burning oil smells a little similar to both... maybe he's experiencing the leaky-valve-cover-dripping-onto-header issue that occassionally crops up?
Old Jan 20, 2011 | 07:31 AM
Velociabstract's Avatar
SRT-6
Valve cover leak. The oil burns off after a few minutes.
Les
Old Jan 20, 2011 | 10:02 AM
c32 AMG
if it is a valve cover leak, how do i go about taking care of that? and what kind of price am i looking at?
Old Jan 20, 2011 | 10:28 AM
King320's Avatar
03 C32 AMG
Yeh. Check this NOW. I had a similar issue and it turned out to be oil, not rubber that was burning. The timing chain tensioner tends to back out on these cars after a while. Mine was leaking oil and the tech said if i hadn't brought it in when i did the rest of the oil would have gone and the engine would have seized.
Old Jan 20, 2011 | 10:34 AM
boohooramblers's Avatar
Not an AMG :(
+1
Old Jan 20, 2011 | 11:55 AM
AMG Sleeper's Avatar
2005 C55 AMG, 2010 VW GTI (Stage 1)
it's the valve cover GASKET - just had the same issue addressed last week. it's the rubber that keeps the valve cover sitting flush.
Old Jan 20, 2011 | 06:19 PM
SRT-6
Usually it leaks from the little valve cover on top of the real valve cover, if you know what I mean. It doesn't use a gasket. High temp black gasket in a tube is all you need. I had mine done by the dealer under warranty but when It started leaking again I resealed it myself.
Les
Here's a link to a how to fix it.
http://www.crossfireforum.org/forum/...over-leak.html
Old Jan 21, 2011 | 08:49 AM
02C32guy's Avatar
2005 E55
My power steering pump leaks fluid and it makes that smell when it burns off. Maybe check that too.
Old Oct 23, 2011 | 10:32 PM
Riko's Avatar
yes, i have exact same problem. can't figure it out! let me know if you do.
also had the valve cover gaskets done, seems to be the same if not worse.
2002 c320
