Made a list of all the necessary parts for stg 1 of my c32 engine build-opinions pls
Old Feb 27, 2011 | 06:05 AM
ByeTurboS4's Avatar
'02 C32 ///AMG, 2000 BiTurbo Audi S4(RIP)
1. EC 185 pulley and tune-also includes - 185mm mechanically dampened crank pulley,Version 2 Water Pump pulley, Idler Pulley with new 19,000 RPMbearings, and OEM Crank Bolt-$999
2. Eurocharged heat exchanger-$425-Is this generally considered the best heat exchanger, for the best price?
3. Johnson CM30 Intercooler Pump-175-This generally considered a good cooling upgrade correct?
4. Needswings pulley kit for 185 pully-$200- I’ve heard this was a necessity
5. NeedsWings Intercooler Fluid Isolation Kit c32--$50
Please let me know if there are any other parts that that I need/should have. Or if there are any better alternatives to what I have listed. TIA
Old Feb 27, 2011 | 06:18 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
6. SL55 Air Intake
7. Data logging (Zeitronix, Dashdaq, Carchip, others)
Old Feb 27, 2011 | 07:39 AM
Newzchspy's Avatar
PLAID
Originally Posted by Lenin
6. SL55 Air Intake (Or Code 3 is you like SC whine and they are available through HPautoworks))
+1
Old Feb 27, 2011 | 07:52 AM
320 dreamer's Avatar
2003 porsche 996 turbo
you can isolate the system for about 3$ and try using a e55 h/e. they are plentiful used
datalogging is a must. dashdaq and zt2 combo
Old Feb 27, 2011 | 01:44 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
contact me via pm. I can do a package deal with everything and the E55 he for ya.
Old Feb 27, 2011 | 03:13 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Is the E55 he better than a code3 he?
Old Feb 27, 2011 | 04:08 PM
ByeTurboS4's Avatar
Can someone explain the datalogger equipment, and brands or whatever these are; Zeitronix, Dashdaq, Carchip.
What is the difference between an E55 HE and the EC HE? WHat do most people on these boards use?
320 dreamer-Is there some type of $ 3check valve that you can use in place of the fluid separation kit? Is there a write up or something on this?
JUAN CASAUS-Im gonna try to answer this so my thread doesnt get jacked by responses to this question. From my research both intakes make power on the dyno but a full SLK55 will make more. Code 3 allows you to hear the SC whine more. There have been a few threads on this recently
Old Feb 27, 2011 | 07:13 PM
Newzchspy's Avatar
PLAID
Six to one, half-dozen to another!! You can no longer get the Code 3 HE since he hasn't made it in almost three years...............It was a very ncie piece when Brandon was making it!! Mine (Code 3) bolted right in with NO mods whatsoever. Get the EC unit, it'll be fine.
Old Feb 27, 2011 | 10:25 PM
chlippo's Avatar
300E W124, 300E W124 3.4 AMG, Audi S3 2002
what bhp do you expect with those bits?
Old Feb 28, 2011 | 01:58 AM
ByeTurboS4's Avatar
As far as Bhp goes stock is what 355? Eurocharged claims +45 hp to the wheels so add 10-20 auto DT loss, and properly tuned for a full SLK55 intake I'd ball park it (hopefully conservatively) around 405-415 bhp (crank).
Id really like to know the deal with the data logging.
Old Feb 28, 2011 | 08:31 AM
Lenin's Avatar
First, google zeitronix, dashdaq and carchip. Then figure out your budget. Follow with lots of reading on your choice.
You need to monitor air/fuel ratio, intake air temp, outside air temp, speed, rpm, tps, timing. There are other params, but these will give you actionable data.
Old Feb 28, 2011 | 10:34 AM
02C32guy's Avatar
2005 E55
+1 (Same goes for the "cool can")
