C32 AMG Intake Assistance
55k Splitter and Boxes with stock filters and aluminized steel pipes to the radiator support.
I've coated the intake tubes in Rustoleum Engine Enamel to try and hold some of the heat back but not sure it's doing such a great job. The ends of the intake are slightly flattened into an oval shape but I think I'm going to bump up the diameter and flatten some more to fill the space and scoop more air.
Right now I'm open to suggestions to make any adjustments and improvements.
I agree with you the intake shall be enlarged to allow more air in, oval funnel design woul do the job to increase the velocity and volume of air ram thru
well done, keep the pics coming
I'll post new pictures for any changes I make to it. Contemplating a thermal coating, header wrap or heat sleeve right now but I'm not sure it make much difference at speed because the air is moving through the pipes too fast to really heat up.
Here is a picture of Advans's C55 with the CLK Kevlar intake. It would be the same for the C32 with the 55 air boxes. Looks (and is OEM) and protects the intake air from heat soak.
