atf
c 32 AMG
atf
hi i drive a c32 amg and i want to change my atf but am not sure with one is recommended so if any one could help me out it would be great..tx
Valvoline
maxlife mb 722.6/nag1 spec.
722.6 diy trans fluid change filter and pan magnet converter fill on the diy forum w210 www.benzworld.org
Work clean,get the special dipstick.
c 32 AMG
so i called (NorthSide Imports INC in Chicago) to find out how much parts would cost
the kit it going to be $25 and the oil is $11 liter i need about (9Liter's) so its going to be around $130..
Doing my DIY differential fluid change next weekend! Pretty pumped.
Kit
filter gasket www.autohausaz.com way under 72 bucks
you need the dipstick and pan magnet
valvoline mb spec maxlife about 5bucks qt at walmart etc.
you need more than 9 qts because in order to drain the 722.6 fully
you need to disconnect the cooling line and flow fluid through the converter otherwise only pulling the pan plug and dropping the pan when drained you will get out under 5 qts and that leaves almost half the old fluid in the transmission.
Critical to get the fluid level correct at the proper temp. Use the mb dipstick tool.
your car does not have one.
