How to remove sunvisor lens?
Old Apr 18, 2011 | 12:02 AM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
One of my bulbs is burnt, can someone please tell me how to remove the len so that I can access to the bulb?
Old Apr 18, 2011 | 03:42 PM
MichaelTC32's Avatar
C32 2002
Removal
I used a small flat screwdriver, they are pressure fit, just move slowly.
Old Apr 18, 2011 | 04:28 PM
Ultraman's Avatar
Do you mean to use a small flat screwdriver to pry it off or push to pull?
Which side of the len that the screwdriver to be inserted?
Old Apr 18, 2011 | 04:39 PM
C32 2002
Removal
Yes from one end, I was able to pry, let me try again and let you know exactly. I'll reply tomorrow.
Old Apr 18, 2011 | 04:51 PM
Ultraman's Avatar
I tried using a credit card to pry it out without success.
Yes, if you can, please take some photos of this "vanity" len and where the tabs are located! Thanks.
Old Apr 19, 2011 | 12:37 AM
Ultraman's Avatar
I figured it now!
There is a slot on each len, each of this slot is facing to the window glass.
There are 2 plastic tabs on each len. Use a flat screwdriver and push the two tabs at the same time and pull the len out.
The festoon bulb inside the len is 36mm.
Old Apr 19, 2011 | 12:13 PM
C32 2002
Removal
Bingo!, I was unable to take photos but yes, on the window side pull down with your finger nails or credit card, then push in on the taps, I also noticed on mine, that it wasnt the bulb. There are 2 contacts on the arm that must line up with 2 other contacts to energize. mine were out of alingment. Pushed it back in a now it works.
Old Apr 19, 2011 | 01:07 PM
Ultraman's Avatar
I used my finger nails and credit card method but no succeed. I suggest using a coin (quarter) or a flat head screwdriver to push the 2 tabs at the same time.
