Replacing supercharger pulley
Beaker-Yes I actually told the dealer rep if I could do that and he said sure except if anything goes wrong they are not liable. Thanks for your input.
not sure what pulley you are looking at as there are no s/c pulleys on the market at this time. there is a crossfire guy who machined his oem down to 66mm or a used c3 if you can find one and the word that e/c will be building a unit but not available for now.
so that leaves a oem unit which cost around 1000$ from the dealer and comes with a new washer and bolt. now is the pulley really bad or just the bearing? if its the bearing hpautowerks or needswings has a replacement bearing for around 50$
That would be a crankshaft pulley. Whole different ballgame friend.
http://www.youtube.com/watch?v=5D78HhG9l9o
Your problem might be the bearing instead of the pulley.
theres a guy parting out a c32 see if he has a oem pulley he will sell
doom239- I think it MAY be the bearing, but the belt or pulley kind of squeaks as it spins on idle.. goes away when I'm on the throttle.
320 dreamer- That's the thing, since the dealer told me the belt/pulley needed to be replaced I assume it is that, also because there definetly IS a belt that needs to be replaced because I can hear it on idle.. almost like a timing belt, but not as high pitched and annoying. Hopefully this shop- European Auto Solutions can fix it without a need for a new SC.
Thanks guys I appreciate the fact you took the time to help
See this thread, which has links to other threads on the supercharger pulley bearing topic.
I used this information to basically coach a capable independent MB mechanic to an affordable fix of my noisy problem.
https://mbworld.org/forums/c32-amg-c...-replaced.html
