My C32 IC rad setup
Old Apr 27, 2011 | 05:58 PM
C32Dan's Avatar
C32
My C32 IC rad setup
will let you know the outcome when the c32 come out of the paint booth, this will go along as isolated system with meziere 22 Gal per min pump
Attached Thumbnails My C32 IC rad setup-img_0058-1-.jpg   My C32 IC rad setup-img_0057-1-.jpg
Old Apr 27, 2011 | 06:24 PM
320 dreamer's Avatar
2003 porsche 996 turbo
thats a lot of blockage to the h/e at speed when you need it most.
Old Apr 27, 2011 | 10:28 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Are those pusher or puller fans? If you mount them on the inside as pullers like the stock radiator fan it should do really well.
Old Apr 27, 2011 | 11:03 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
By the way they are mounted it looks like they will be on the outside..
Old Apr 27, 2011 | 11:44 PM
2005 E55 AMG
Thats what I was thinking...
Old Apr 28, 2011 | 12:36 AM
Beaker's Avatar
2001 C32 AMG
Is that the PLM HE?
Old Apr 28, 2011 | 06:55 AM
C32Dan's Avatar
C32
Originally Posted by Beaker
Is that the PLM HE?
it is a PLM with 500 cfm pusher fans
Old Apr 28, 2011 | 09:16 AM
2005 E55 AMG
Is there any way to get puller fans that way they don't obstruct the ic?
Old Apr 28, 2011 | 10:43 AM
WaveyKat's Avatar
Something Slow
question: how can you tell the difference between the PLM & Code3 Heat Exchanger?
What Brand is in the Pic Attached i was told its Code3
Attached Thumbnails My C32 IC rad setup-he.jpg   My C32 IC rad setup-he-2.jpg   My C32 IC rad setup-he-3.jpg
Old Apr 28, 2011 | 05:45 PM
C32Dan's Avatar
C32
PLM brackets are on top and the core is thicker
Old Apr 28, 2011 | 05:55 PM
Newzchspy's Avatar
PLAID
Don't believe those fans will help much above 20 MPH or so?? The PLM and Meziere alone should be more than enough to drive down those IC temps, unless you do a lot of stoplight to stoplight, slow driving and profiling??
The Code 3 and Johnson on mine do an amazing job.
Old Apr 28, 2011 | 06:14 PM
C32Dan's Avatar
C32
The plan is to have them on a switch for in town driving they should help on recovery time between red lights
Old Apr 28, 2011 | 06:31 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Are you planning on logging any IAT data? What will you be using?
Old Apr 28, 2011 | 06:44 PM
Newzchspy's Avatar
PLAID
If they're in front though (pushers) won't they impede the air flow at higher speeds???
Old Apr 28, 2011 | 09:46 PM
C32Dan's Avatar
C32
I do plan for IAT gauge I still to do some research to see if I can tap the existing sensor or install another one MTF.
Old Apr 28, 2011 | 10:00 PM
C32Dan's Avatar
C32
I figure with the size of the PLM the little restriction cause by fans will not be a great deal plus I live in Canada where heat it not too much an issue !!
Old Apr 28, 2011 | 11:27 PM
WaveyKat's Avatar
Something Slow
so PLM is better then?
Old Apr 29, 2011 | 02:49 PM
Newzchspy's Avatar
PLAID
Define better?? At what, reducing the IATs or installation. My Code 3 was a breeze to install. He's in Canada, so its probably a moot point. Talk to me in Texas or AZ about temps.
Old Apr 29, 2011 | 03:09 PM
2005 E55 AMG
My Code3 works really well for me here in New Mexico
Old Apr 29, 2011 | 03:22 PM
Newzchspy's Avatar
PLAID
+1!!
Note that being in Canada, unless you're profiling (cruising) etc, I don't see the need for the three fans...........How often are you doing less than 20-25 MPH anyway for extended periods.
Old Apr 29, 2011 | 03:55 PM
2005 E55 AMG
+1!!
+1...have you even tried the HE without the fans. I don't even think I need that here and it'll definitely get over 100 degrees
Old Apr 29, 2011 | 04:31 PM
thicker isn't always better. the optimum h/e is a h/e that has the greater surface area to allow more air to pass thru. putting the fan in front simply blocks the airflow. any benefits from the fans will be negated by the blockage
Old Apr 29, 2011 | 07:01 PM
C32Dan's Avatar
C32
Well I see lots of speculations here about it and its all good, that`s forums are all about its to learn about ea others, that said I do lots of driving in heavy traffic going back and forth to Ottawa, I think the fan shall help in hot temperature, don`t go thinking we have snow banck here all the time we get in the 100 in the summer with 80% humidity. As for the restriction the fans cause well I did my homework on this and all fluids are compressible to some extent, that is changes in pressure or temperature will result in changes in density and go around the fan body. However, in many situations the changes in pressure and temperature are sufficiently small that the changes in density are negligible.
I guess a tap in gauge in the IAT sensor would reveal the pure truth, does anybody ever tap in the IAT and connected it to a gauge.
Old Apr 29, 2011 | 08:29 PM
Lenin's Avatar
Whatever you do with the fans (I personally have my doubts) don't tap the IAT sensor. Get an OBD2 based monitoring solution. CarChip or iPhone App. There may be other inexpensive (relatively speaking) solutions.
Old May 1, 2011 | 11:22 AM
WaveyKat's Avatar
Something Slow
where did you Purchase the meziere Pump? and is it better than the Cm30?
