Help looking for a solution
Problem: Apart from a slight vibration at about 70mph the only other problem is I cant set the speed control at any speed above 60mph. Also the "Resume" function does not work reliably. Is there any solution to the speed control problem? has anyone else had this problem. I am assuming its due to the over-sized and or mismatch size of the tires.
John
ps. I tried several search key words without much luck. I know there has to be some one out there who has had this problem.
18x8 ET30 (ET25 with spacer)
Inner clearance 1mm less - outer clearance extend 11mm extra
Rear
18x9 ET39
Inner clearance 8mm less - outer clearance extend 4mm extra
Stock
18X7.5 ET30 and 18X8.5 ET37
Pretty sure he's talking about the tire width.
As far as the front and rear track go in stock form the front track is 16.5mm wider each side than the rear. With the above wheels that changes to 23.5mm. However that's an increase in front track width of less than 1.5% and the rear increases by 0.5%
John
Size Diameter
225/45R18 25.9 WS70
245/40R18 25.7 XS
265/35R18 25.3 XS
225/40R18 25.1 PZero
245/34R18 24.5 PZero
So the tires I have on now are closer to stock than the winter tires I had been using?
