C55 Front Brake job is in my future
1) Are the brakes on the C32 and C55 the same? ie, can I use the same write-up instructions?
2) I've read both, you can turn the rotors, you shouldn't turn the rotors, etc. Look, I'm of the opinion that you should be able to. Every set of rotors I've ever seen could be turned. I'm not driving the car to the track...its my wifes daily driver, so there won't be any heavy braking on the rotors. NAPA says they can turn drilled rotors so I'm planning on having them turned. My car has 90k miles so if the rotors have ever been turned they haven't been turned buy maybe once so I'm guessing the thinkness won't be an issue.
Thoughts?
Thoughts?
I never turn mine.
Rockauto has the best prices and very quick shipping.
Yes, I would turn rotors on something heavier because it only makes half the power. Momentum is a function of weight and power, not just weight. Faster you go, more force is required to stop you. Kapish?
http://youtu.be/opWb7pideFg
