steering rattle
Old May 24, 2003 | 06:53 PM
mhh's Avatar
mhh
2012 MB E63 Wagon, 2012 BMW M5, 2010 Porsche 911 Turbo S, 2010 Ferrari 458
steering rattle
On some bumpy surfaces, I get an occasional rattle back through the steering wheel. It is hard to demonstrate the problem at the dealership as it only does it on rough roads.
Has anyone had this fixed, or do we just put up with it?
Old May 24, 2003 | 08:52 PM
W0n6_3d4n's Avatar
C200K (w204)
I had this problem a while ago, the dealer fixed it and it came back again . Anyway, the dealer told me they tighten up something on the steering wheels. I can duplicate the problem by hitting the lower part of the steering wheel (don't hit it too hard, hehehe), just a nudge will do.
Old May 24, 2003 | 10:06 PM
mhh's Avatar
mhh
Thanks for the tip. I just tried the "hit the wheel" trick - and sure enough, that's the noise. I'll see what the dealer can do.
BTW, that's some handle........and I thought mine was catchy!
Old May 25, 2003 | 06:49 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
mine doesn't rattle. It clicks when turning at parking lot speed...
Old May 26, 2003 | 02:03 AM
box986's Avatar
W211 E63
Re: steering rattle
I have a similar problem on my C32, I can even feel it when the car is not running. All I have to do is wiggle(spelling) the steering wheel around left and right quickly. My dealer replaces 2 steering rack and the dealer is still there, then I went to another dealer and I got a different explanation from them.
The explanation that I got from the dealer is that the feedback comes from the "Z" shape machanism for the tilt & telescoping adjustment function for the steering wheel. The feedback kinda goes away when I adjust the steering wheel outwards more(towards the driver).
Old May 26, 2003 | 03:58 AM
mhh's Avatar
mhh
Thanks, I'll try that and see if it helps.
Old Jun 5, 2003 | 01:37 AM
c32brabus's Avatar
I had a similar problem with a loose steering wheel being lose when i took the car to the dealer they found out that on the right front, one of the arms had a bushing that was leaking oil. This arm is supposed to help prevent nose dives while braking hard. The problem went away but i think i gotta take it in for them to change the left side bushing too.
Old Jun 12, 2003 | 11:55 PM
c32brabus's Avatar
WELL I FINALLY TOOK THE CAR IN AND THEY'RE WORKING ON IT. THE PROBLEM WITH THE LOOSE STEERING WHEEL I GUESS WAS THAT THE BUSHING ON THE CONTROL ARM WERE WORN OUT SINCE THE CAR HAS BEEN LOWERED, COOL THING IS THEY DIDN'T CHARGE ME FOR THEM
