C55 - Annoying Door Lock Nobby
Old Aug 1, 2011 | 12:41 PM
ZachG's Avatar
2006 C55 AMG
Hey,
So, I like to drive my C55 with the windows down with my arm on the door *1. However, the little *** which goes up and down to indicate that the door is locked/unlocked really gets in the way of my arm in my normal driving position.
Has anybody else had this issue? Can we get a replacement *** that doesn't stick up as tall perhaps?
Thanks!
-Z
*1 Like this guy: http://www.profimedia.rs/photo/man-s...0035611312.jpg
Old Aug 2, 2011 | 08:55 AM
p911guy's Avatar
AMG C32
I had the same problem, but a set of new door lock pins off of EBay solved that. The OEM pins twist right out, the new ones twist right on, but require a bit of force and I ended up with a blister. Here's the pins I bought, but can't remember if this is the same guy I bought them from : http://cgi.ebay.com/ebaymotors/BENZ-...#ht_2839wt_941
Old Aug 2, 2011 | 09:33 AM
ZachG's Avatar
2006 C55 AMG
I can't tell from the post if these guys are shorter or less obnoxious than the OEM ones. Do you have a photo of them installed perchance?
Old Aug 2, 2011 | 09:36 AM
p911guy's Avatar
AMG C32
They're shorter and they sit flush against the door itself. I'll try and take a pic when I get a chance later.
Old Aug 2, 2011 | 01:37 PM
mgiannetto's Avatar
'06 C55, '14 Audi S4, '09 Range Rover Sport, '07 Lexus ES350,
They look like the ones I got, which sit pretty much flush when the doors are locked. Have a look at the pic's I included in my post #12.
https://mbworld.org/forums/c32-amg-c...oor-locks.html
Dresses up the car and eliminated the annoyance you rightly point out. A complete no-brainer.
Old Aug 3, 2011 | 09:57 PM
MercedesFTW's Avatar
Cee Fiddy Five
If you do a search, there is an old thread with part numbers for the CLK door lock pins (or maybe E-class?). Either way they look the exact same as the stock C55 ones but they sit flush when locked and cost $6 at the dealership.
Old Aug 13, 2011 | 01:47 AM
ZachG's Avatar
2006 C55 AMG
Huge +1. These came in today. Managed to install them on the front doors (don't seem to work as well on the backs, but I don't care about the back). Works perfectly in the front!
I can't tighten the fronts 100% though or the door locks can't lock, but I loosen them 2 or 3 turns all is well with the world Totally worth the $30 or so.
