Eurocharged AMG Speed Shift TCU Flash - $499
Old Dec 1, 2011 | 12:06 AM
  #126
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by C_DirtyTwo
Jerry actually called me today when he was about to take care of my tunes and recommended a 6600rpm redline which would be more beneficial because of my intake...so I said go ahead with it and 6600 it is. I guess you can go up to 6900 but I don't know about that for me haha
Wow, does that make you the highest revving C32? I haven't heard of anyone up that high. But, hey hopefully it works out for you.
Old Dec 3, 2011 | 03:40 PM
  #127
C_DirtyTwo's Avatar
a land yacht.
well I got my ECU and TCU back this morning...The car was sitting for just about a week so I gave it a good while to warm up and just run. Took it out for a drive to get some gas and check out the new tunes. I cruised around to let the TCU kinda adapt to driving again as well as the ECU.
My review so far:
After just one pretty quick drive around town testing it out all I have to say is YES. The car shifts noticeably faster and in combination with the higher revs seems to really pull hard on the top end. The manual mode is cool, being able to shift at really any RPM and having a quick response is nice. Its a cool and windy day here with air temps in the mid 50's so the car was running great. The tunes definitely unleashed the beast!
I'll update you guys after I get a chance to drive her around a bit more
Old Dec 3, 2011 | 05:03 PM
  #128
AMG3.2's Avatar
C63 AMG, P30
My review so far:
Nice! Thanks for the short review
Old Dec 13, 2011 | 07:16 PM
  #129
Zeppelin's Avatar
C32
So there is a M/S/C mode with the TCU tune.
I know what M is and used to know what S and W was.
What does "S" and "C" do after the tune?
Old Dec 13, 2011 | 07:56 PM
  #130
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
New "S" and "C" are like two versions of the old "S". "S" is more sport and is a bit more aggressive than the old "S" while "C" is more "comfort". Both start in 1st gear.
Old Dec 14, 2011 | 07:23 AM
  #131
Justsaymo01's Avatar
2002 C32 AMG
Could you explain what the raised torque limiter part of it does, and does the C mode seem to be a smoother shift than factory. It seems like after my ecu tune, and s/c pulley upgrade it doesn’t shift as smooth or consistently as before under normal driving conditions. Would the increase in power and torque cause from the upgrades have anything to do with the symptoms.
Old Dec 14, 2011 | 10:49 AM
  #132
Lenin's Avatar
Sorry but I can't remember how my car was from the factory. I got it 10 years ago. By itself C mode is smoother than S but is it "Mercedes smooth" after you added an ECU tune and a pulley? - no. Raised torque limiter is not for everyday driving. It's for more aggressive driving and track racing. For now, I'm not sure what it does. Still testing and logging.
Old Dec 14, 2011 | 07:48 PM
  #133
2002 C32 AMG
Thanks for the info sounds like the TCU tune is going to be my next upgrade.
Old Dec 14, 2011 | 10:16 PM
  #134
SYZYGY's Avatar
C32, E93 M3
Would this TCU tune prevent premature torque converter lock-up under moderate acceleration? I f-ing hate it when I am rounding a corner and go to accelerate out of it only to have the dame torque converter lock up and the car bog. So I end up mashing the gas to punish the car for its misdeed and then the transmission downshifts, which I don't want either.
Old Dec 15, 2011 | 12:36 PM
  #135
Newzchspy's Avatar
PLAID
Meaning?? Are you feeling any difference (seat of pants so far??)
Old Dec 15, 2011 | 02:14 PM
  #136
C_DirtyTwo's Avatar
a land yacht.
There is definitely a difference, however I have noticed that while driving in regular S mode the car will occasionally bounce off the revlimiter when shifting at WOT even without loss of traction which I do not like.
With the 6600rpm redline...the car used to shift right before 100mph but now pulls through hard in the high rpms past 100mph which is amazing.
The butt dyno noticed some power for sure, the car feels smooth and shifts extremely fast
Old Dec 15, 2011 | 08:30 PM
  #137
Zeppelin's Avatar
C32
Recieved my ECU/TCU back yesterday and am extremely pleased with the results. Only spent an hour behind the wheel so far and have not played with C or M modes.
I had a SpeedTuningUSA flash from about 9 years ago with my EVO Sport pulleys and this tune pulls much harder in the upper revs. Low down torque is improved as well. Seems like the car does not down shift as early as it used too but it is probably still learning as all the adaptations were cleared.
Adam and Jerry were a pleasure to work with.
Old Dec 15, 2011 | 08:54 PM
  #138
dre5373's Avatar
2006 C55, 1995 C36
Is this from 3rd gear to 4th? My C55 shifts to 4th around 110, and just wondering if from a drag racing standpoint, if it would be worth getting just to avoid an additional shift before the end of the 1/4...an extra few hundred RPM's might help aside from the quicker shifts
Old Dec 15, 2011 | 09:33 PM
  #139
Lenin's Avatar
Originally Posted by Newzchspy
[/U][/I][/B]
I feel the difference. I also log a lot of data and at the track I see that shifting into 3rd at about 60+ MPH my AFR gets a bump to 18+. Not sure what that means and why. Spirited daily driving is fine and I don't see the same issue. I played with M mode at the track and it will take some time to figure out. But it is a lot of fun.
I see the same bounce off the rev limiter on occasion. Shifts are faster in lower gears. The most RPM I hit at the track is 6450 and the car doesn't shift until 106MPH while in the past it shifter around 99-100.
Even with the AFR spiking to 18 at shifts, with the last shift being at 106MPH I now run at 113.8-114.3 at the end of the 1/4 vs. 112.25 in the past.
Old Dec 19, 2011 | 06:46 PM
  #140
Zeppelin's Avatar
C32
I am noticing something similar and I can't tell if it is hitting the rev limiter before the shift or the shift is so hard. Whichever it throughs you forward in the seat for a second so I think it is the rev limiter. Maybe my TCU is still learning
Old Dec 20, 2011 | 02:21 AM
  #141
AMG3.2's Avatar
C63 AMG, P30
Same thing is happening to my car... It's almost like you hit a wall for a second... and then it shift. It only happens once in a while though.
Old Dec 20, 2011 | 08:54 AM
  #142
Lenin's Avatar
What you are seeing is this.
The area in red shows the drop in TP%, RPM and Boost while the AFR rises to 20+. This one is at 106 MPH. You can also see another shift point at 60 MPH that is also associated with a spike in AFR.
Attached Thumbnails Eurocharged AMG Speed Shift TCU Flash - 9-12-20-2011-8-41-44-am.jpg
Old Dec 20, 2011 | 11:40 AM
  #143
AMG3.2's Avatar
C63 AMG, P30
so is this bad for the car? It certainly doesn't feel good...
Old Dec 21, 2011 | 08:18 AM
  #144
Lenin's Avatar
I don't know yet. The theory of it is not good.
Old Dec 21, 2011 | 10:59 AM
  #145
AMG3.2's Avatar
C63 AMG, P30
Well that's just great. Is this a problem everybody with the TCU flash is experiencing? Or just me and you...
Old Dec 21, 2011 | 11:14 AM
  #146
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
the cars cut fuel on shifts...mercedes design...
Old Dec 21, 2011 | 11:43 AM
  #147
Lenin's Avatar
I didn't call it a problem yet. Just an observation.
Jake, can this behavior be programmed out of the mercedes design? Also, my fuel is still at above 50 PSI at the shift points. Are you sure the fuel is being cut off? If this was a belt slip, how would I tell?
Old Dec 21, 2011 | 12:23 PM
  #148
buffyclk500's Avatar
clk500
i happens 2 me when the trans temp is under 80c
is this happening 2 u all after warm up
Old Dec 21, 2011 | 12:51 PM
  #149
MBfinatic's Avatar
e36 318i, 2004 sti
Anyone do this to the C55?
Old Dec 21, 2011 | 01:43 PM
  #150
Zeppelin's Avatar
C32
Happens to my C32 most of the time even after warm. If it was part of the original design I would of noticed it before the TCU mod. Only time I ever noticed something similar was on a 1-2 shift maybe once out of 500 shifts it would hit the rev limiter with the stock TCU. Now it happens on the 1-2, 2-3. Not sure if it would happen on the higher shifts as I have not done a wide open 3-4 (no space).
Is the problem because of the raised rev limiter and shift point or because of the faster shifts?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
