Eurocharged AMG Speed Shift TCU Flash - $499
Old Jan 4, 2012 | 02:00 PM
  #176
C32maximus's Avatar
2003 C32 AMG
I will be sending out my TCU to EC within a week. I will talk to Jerry about the best way to integrate it with the Stage 2 tune installed late last year. I think I will have EC set the rev limiter of the TCU 100 to 200 rpms lower than the ECU in hopes of not having this problem on max redline shifting. I look forward to hearing his take on this.
Old Jan 4, 2012 | 03:45 PM
  #177
AMG3.2's Avatar
C63 AMG, P30
That might work. Let us know!
Old Jul 5, 2012 | 06:14 PM
  #178
RedBull's Avatar
CLK550
So what ever happened with the V2? Did it clear up the issue?
Old Jul 6, 2012 | 09:14 PM
  #179
cjw's Avatar
cjw
Srt-6
Version 2 was not fixed at least for the Srt, we had ours sent back mulitple times to EC and kept having the same issue, still waiting on my return money for the tune
Old Jul 7, 2012 | 01:54 PM
  #180
Zeppelin's Avatar
C32
If you mean the hitting the rev limiter at the shift point then yes it is fixed in the C32.
Old Jul 7, 2012 | 02:04 PM
  #181
320 dreamer's Avatar
2003 porsche 996 turbo
i think he meant the high afr spikes that occured during the shift
Old Jul 7, 2012 | 07:25 PM
  #182
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Yep. That's what I want to know.
Old Jul 7, 2012 | 07:49 PM
  #183
C_DirtyTwo's Avatar
a land yacht.
They have my ecu and tcu right now to retune it since mine was hitting the rev limiter...I'll call them on monday to ask about the afr spike
Old Jul 7, 2012 | 09:14 PM
  #184
AMG3.2's Avatar
C63 AMG, P30
I sent mine in a while back with regards to the AFR spike. Jerry said he had fixed it a while ago. Hopefully this is the case...
Old Jul 8, 2012 | 04:04 PM
  #185
RedBull's Avatar
CLK550
I've been giving thought to this mod, but want to make sure the bugs are worked out. I was curious about the spike, as well as bouncing off the rev limiter.
Old Jul 9, 2012 | 08:42 PM
  #186
C_DirtyTwo's Avatar
a land yacht.
Spoke with Jerry today...I guess the issue with the fuel spike is only when you have the shift points raised to higher RPM's. Which was my case at 6600, so back to 6250 and fuel spike is gone.
Old Jul 9, 2012 | 08:54 PM
  #187
AMG3.2's Avatar
C63 AMG, P30
Weird, that's not what I was told... My car still shifts at 6.5k. I just don't know what to think any more about this software...
Old Jul 9, 2012 | 10:29 PM
  #188
C_DirtyTwo's Avatar
a land yacht.
Well I guess that since there is no software for the ECU when the transmission is revving higher the ECU goes wack when the car revs higher than it should (afr spikes). They have to find or write software for the ECU to know what to do when the TCU revs higher I think. either way, Id rather be safe than sorry so I'll be happy with the M mode and faster shifts with the stock shift points for now.
I guess the only way to really know what your car is doing is to data log.
Old Jul 10, 2012 | 01:35 AM
  #189
RedBull's Avatar
CLK550
So is there any noticeable difference in having the torque limiter raised?
Old Jul 10, 2012 | 09:41 AM
  #190
AMG3.2's Avatar
C63 AMG, P30
I have the ECU and TCU tune and I didn't notice any torque limiter difference? Sure the car feels faster, but it should because I installed a E/C S/C pulley as well. Not sure what the whole "removing torque limiter" statement even means.
Old Jul 11, 2012 | 02:55 AM
  #191
tw2's Avatar
tw2
I don't know if this is correct or if it answers your question. I wanted to know also but could not find any info on the forum. I believe raising the maximum level of allowable torque will stop the engine reducing power when it is exceeded (ie when modified). I guess it is to protect the tansmission? Typically happens near redline and could be confused with fuel cut on a turbocharged car or a harsh gear change.
Old Jul 11, 2012 | 10:32 AM
  #192
AMG3.2's Avatar
C63 AMG, P30
Makes sense. I wish we had a more concrete info about the tcu tune. It seems a lot of information is up in the air.
Old Jul 14, 2012 | 12:11 PM
  #193
C_DirtyTwo's Avatar
a land yacht.
Got mine back with stock shift points, car feels noticeably slower :dunno:
Old Jul 14, 2012 | 01:45 PM
  #194
AMG3.2's Avatar
C63 AMG, P30
umm that sucks lol When I got mine retuned, it felt the same.
Old Jul 21, 2012 | 10:59 AM
  #195
johnng117's Avatar
2002 C32 AMG
Should I send my TCU in for a tune? I was thinking of sending it next weekend.
Are all the problems ironed out?
Old Jul 21, 2012 | 04:16 PM
  #196
Zeppelin's Avatar
C32
It depends on what you are looking for. If you want the higher shift points or manual mode then I say yes. If you keep the stock shift points and could care less about M mode then I would not.
I don't use the manual mode but the higher shift points make the thing scream during shifts. It comes at a price which is during around town average driving the transmission shifts too soon. It will shift quickly from 1st to 2nd to 3rd before hitting 20 mph and then if you want to pickup speed the motor is bogging and it takes an inch or more of throttle to get it to downshift. Never did this stock.
Old Jul 21, 2012 | 08:33 PM
  #197
AMG3.2's Avatar
C63 AMG, P30
Zepplin, you have mentioned something that I never understood about the TCU tune. When driving in S or C it shifts through gears ridiculously quick to the point where the motor is bogging so hard... Do you know why this was done? For this reason, I NEVER drive it in auto... It's just horrible sounding
Old Jul 23, 2012 | 09:38 AM
  #198
Zeppelin's Avatar
C32
To clarify - my car with the TCU tune upshifts at light throttle much sooner than the stock TCU. For example accelerating from a stoplight at light throttle it will shift to 2nd and then 3rd gear at 1500rpm. So if you then decide you want to go faster you are in 3rd gear at 1500rpm and the car is sluggish (1500rpm = no wonder it is slugglish). You then have to push down about a inch on the throttle to get it to downshift.
I have not heard this complaint from anyone else so maybe it is just my car.
Old Jul 23, 2012 | 10:38 AM
  #199
AMG3.2's Avatar
C63 AMG, P30
Well no, my car does the exact same thing. It goes through gears quick and shifts at 1500RPM every time at light throttle. My car does the same exact thing. I thought it was only my car lol I guess not.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
