torque strut removal 2003 C32
Greetings, I'm replacing the torque strut and need to know the size of the allen key needed to hold the upper wheel carrier bolt while I remove the nut. Please see attached .pdf
C32/C55 AMG
Check your differential drain plug and see if it's the same size, if it is then it's a 14mm hex/allen. I purchased this set to do the differential fluid change, maybe it will have the hex socket that you're looking for: http://cgi.ebay.com/ws/eBayISAPI.dll...m=380373575477
Check out this link for suspension install: http://www.mymbonline.com/forum/160-...-included.html
