All C32 owners!
Old Oct 18, 2011 | 12:52 PM
c32kompressor's Avatar
CLK55 AMG
All C32 owners!
If you've had the dreadful throttle actuator malfunction, it is NOT your actuator. It's the electric plug on the actuator. It has a loose connection and pulls a code for the throttle actuator. I fixed mine this way by zip tying the plug agains the intake manifold. It will loose it's connection and go out. I'll post a video later. A way to diagnose this is to turn the key to accessories and listen for a high pitch buzz that comes from the actuator. If you don't hear it then push on the plug towards the intake manifold until you hear it. Then zip tie it so it stays.
Old Oct 18, 2011 | 01:36 PM
C_DirtyTwo's Avatar
a land yacht.
Good to know...I'll check mine today. I really hope this fixes it!! I'm excited to try it!
Old Oct 18, 2011 | 01:39 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
I tried a new cable and Zip tied it as well, but it was still my throttle body that was bad.
Old Oct 18, 2011 | 01:42 PM
C_DirtyTwo's Avatar
a land yacht.
Well I just replaced my TB which temporarily fixed the problem...but it's back again. The TB is an E55 one and used so it could have gone bad as well I suppose.
When I get the symptoms, unplugging and plugging it back in seems to temporarily fix the problem.
I will try the zip tie today and update how it goes.
Old Oct 18, 2011 | 01:48 PM
CLK55 AMG
The plug gets tired and looses its connection. Now of coarse it can still be the actuator, but this tends to be the issue more than the actual actuator
Old Oct 18, 2011 | 02:11 PM
loudandheard's Avatar
C32/C55 AMG
I just can't see much that can go bad with the throttle body and it should be a fairly straight forward rebuild if something does go wrong. Looks to be nothing but gears and few other things.
Old Oct 18, 2011 | 02:41 PM
2002 C32, 2012 S550
I had mine rebuilt.
Old Oct 18, 2011 | 03:50 PM
testknight's Avatar
CLS55
what are the symptoms when this issue occurs (want to log this thread in back of my head for future reference, but I'm not even sure what problems this fixes). When the throttle actuator is not working, how does the car behave?
Old Oct 18, 2011 | 06:58 PM
CLK55 AMG
youll have a hunting idle, low idle, car can stall. and absolutly no throttle response. youll get a warning on the dash that says "esp unavailible. visit workshop"
Old Oct 18, 2011 | 07:30 PM
ddtham's Avatar
C32, 911 SC
Ditto. I had the same problem and ended up cleaning the connector with electrical cleaner and zip tied it. No problem so far.
Old Oct 19, 2011 | 11:12 AM
johnng117's Avatar
2002 C32 AMG
I will try this tomorrow, just in the process of changing my ECU. I've clean the connections but have not cable tied it.
Old Oct 19, 2011 | 04:52 PM
C32maximus's Avatar
2003 C32 AMG
I tried the zip tie route with mine and cleaning the connections but it didn't work for me. You made a good point about the method of testing the connector though. The throttle body off the E55 I used has a sealed connector on the throttle body. It is obvious Mercedes knew the plug had issues.
Old Oct 20, 2011 | 01:51 AM
pointman's Avatar
a car that can't do the throttle reset.
wtf?? I feel like I am on here a good amount reading about whats going on.. how did I miss this being an issue??
Old Nov 1, 2011 | 01:29 PM
C_DirtyTwo's Avatar
a land yacht.
well it has been a couple weeks since I zip-tied the plug together and so far so good...I hope I am not speaking too soon but I think it fixed it!!!
Holy cuss that saved me a lot of time and money and effort! thanks c32kompressor!
Old Nov 1, 2011 | 09:41 PM
CLK55 AMG
Just looking out for us!!
Old Dec 20, 2011 | 12:30 AM
DerHammer's Avatar
C32 AMG, E55 AMG (w211)
I've had this p0120 problem as well since I got the c32 and have tried everything. I've really just lived with it since it goes away usually if I reset the battery, clear the code, or wiggle the plug.. Good to hear that it might just be my plug.
Old Jan 22, 2012 | 01:24 AM
marvan's Avatar
C32 AMG
I have a 2002 c32 and it keeps going into limp mode,but no errors show up.
Is this the same problem?
