Driver's seat wont automatically set/adjust
Mercedes C55 AMG
When i put the key in the ignition, or take it out, the seat doesnt move back to the resting position, or adjust to my seat memory settings. The buttons still work to move the seat around, it just doesn't set when i get in or out of the car anymore. it just stays in my "memory two" setting. Anyone had this problem or know what it could be?
-Mike
-Mike
1 Post
1996 S420 2006 C55AMG 2002Mustang GT
did you take it out of the convience mode, i think that controls the seat and wheel settings when you put the key in. im not 100% on that though so dont quote me.
2005 C55 AMG
...hum..... sounds like an expensive problem
In actuality, the settings within the gauge cluster will dictate what moves and when. Chedeng88's is just probably broken. Try moving it all of the way up when you get out of the car next time you exit and notice if it moves back into position when you return.
Also, if you've changed keys recently and you have key dependancy turned on, all of your settings will be dependent on the new key.
I have "steering column + seat" set on both keys, but it's only working with one key.
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
yup, same problem, happened when we started using two sets of keys. Also the park assist mirror would work intermittently. I just gave up on it.
C32/C55 AMG
As for the park assist, I don't use it because I'm worried that it's going to go out and my seat is going to get stuck. I know the adjustment for the steering wheel breaking is a common problem on our cars.
The side mirror dip during reverse only works if you leave the mirror adjustment selector button pushed in for the passenger. if you leave the selector in driver side, it wont dip
