Anyone want to come out this fri to do some 1/4 times?
Old Nov 7, 2011 | 04:09 PM
MBfinatic's Avatar
e36 318i, 2004 sti
A group of us are going this friday and was wondering if anyone would like to come out as well. This friday the 11th at Virginia motorsports park.
Old Nov 7, 2011 | 04:57 PM
petez1125's Avatar
2007 E350 4 Matic Silver/Ash and 2005 C55 Black/Black
I wish I could go. We leave Thursday for FL for a mini-vacation. Sounds like fun.
Please post the times you guys run.
Pete
Old Nov 7, 2011 | 05:47 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
Pete
+1. tim, is this your first time running the 1/4 mile? on street tires too? i want to see if you'll beat my first time running
Old Nov 7, 2011 | 06:54 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Did you do a burnout your first time? I dont get how you times were that bad, even on street tires.. I was even able to get a 2.0 60' on street tires in 40 degree weather two weeks ago..
Old Nov 7, 2011 | 07:35 PM
MIKESV8's Avatar
i absolutely dread making excuses when it comes to crappy races, but i'll give you my conditions i was working with. first time EVER going to any sort of track. i had no clue the pavement would be that slick. my tires were ps2's that were about 6 hours old at the time (yea, i got them that morning) i had just gotten the ecu flash the day before AND i did the transmission adaptiveness reset that morning for the first time in months so i was still getting used to the power, it was basically a different car. i did not burn out. i have a video of me just mashing on the throttle on my first run ever and just going up in smoke and sideways. then it got progressively better from 16.5, then to 14.5 then it was over. i'll run MUCH better next time. my first run, my itty bitty slick 245's were at 40 psi (that's what the guys that changed my tires put them at) so i just kept on lowering them until i got to my last run where i got them to 22psi with still some wheel spin. i'll start it off at 18psi next time and feather on the throttle more and run in sport mode instead of manually trying to hit the shift points myself. live and learn fellas. can't wait to get the new car in june/july i'm sure i'll be much better at launching by then. oh and in my 14.5 second run, my friend i was running against got a 13.something time, but my trap was higher by 0.01 of a second.
Old Nov 7, 2011 | 08:44 PM
AKnight55's Avatar
You got to do a burnout for sure.. If you dont all the little rocks stick to the tires because of the vht and make it even worse.. Make sure to do a burnout next time and leave traction control on
Old Nov 7, 2011 | 10:19 PM
MBfinatic's Avatar
e36 318i, 2004 sti
How do I get my traction control to actually stay off. If I hit esp off if you wait a min or so to launch it will act as if it was engaged? Im thinking about running in dyno mode.. but I dont remember how to put it in dyno mode
Old Nov 8, 2011 | 12:12 AM
dre5373's Avatar
2006 C55, 1995 C36
Post #43...
https://mbworld.org/forums/c32-amg-c...no-mode-2.html
Old Nov 8, 2011 | 12:37 AM
MIKESV8's Avatar
Originally Posted by dre5373
don't go into dyno mode tim!! just warm the tires and do your thing.
also, if you want it to shift faster and get less lag off the line, reset the adaptiveness
Procedure:
1. Place key in "on" position, not start;
2. Fully depress the accelerator for five seconds;
3. With the accelerator full depressed, turn key to "off" position.
4. release accelerator;
5. wait at least two minutes before restarting the car
