Q about mod. on C32
my friend has a C32 now , everthing is in stock , and he is wondering that is it possible to mod. his car has over 400HP
since he just wanna be more fast on straight line , is it possible to install or upgrade the supercharge eg. kleemann supercharge kit .....
sry that I duno anything about the C32 amg , so I would like to get any advice from u guys , thank you very much ^^
by upgrading the pulley kit , how many Hp would be gain ?
also , is it possible to install a Kleemann supercharge kit on the C32 amg ?
thx a lot
Do a search on the board and you will find lots of information about tuning.
Keep in mind that not all C32 come with the same HP from the factory. Some have 300 HP at the weel, mine had 279 and some had even less. So to know how much you are gaining you should really know how much HP you have before doing any mods.
Our system is typically raising hp by 45 to 50 and tq by 55 to 60, $3500.
You should test the car before and modifications to see where you are- we have seen C32's vary a great deal in the power they make from the factory.
I personally am not going to beleive the outcome of anymore of these C32 dyno's. I have seen to many inconsistencies with the same car. It seems the heat soak in the intercooler and the ECU retarding timing geatly affect the outcome.
Sure there may be some heat related issues but ask the Evosport guys ... they have tested and retested for the OPDS R&D. They will tell you that there are HP differences regardless of heat soaking or any other factors.
You cannot use a KLEEMANN supercharger on topof the AMG unit and it makes no sense to replace the existing unit. KLEEMANN has a pulley and ECU upgrade combination that can easily push you over the 400 crank HP mark.
kleenman! your pulley kit is out? or is it to be announced?
Jerry
Jerry
This was the case with Tim as his car did not fully adapt to ODPS.
The cars that are low today will still be low 10 days from now. I fthe same testing procedure is used the results are very repeatable.
For optimum results, doing before dyno is always recommended.
and a final Q , my friend just wonder if he can install a big turbo kit on his C32 .... is it possible ???
thx a lot
However I must disappoint you because it was a one time installation. In fact I talked to the engineer that designed the whole installation a couple of weeks ago (MKB guy). The car works, but due to its extremely complex mods the car is not your daily driver anymore ...
