Idler pulley bolt torque spec on C55
2006 C55 AMG White/Ash
I have done a search and there is conflicting info, could someone who has access to a shop manual for C55 please list the torque spec for the bolt. I'm replacing mine soon and just want it right. Thanks, Phil
2008 A8L, 2002 996TT X50, 2009 X5
Not specifically what you requested, but in case it helps: C32 idlers are torqued to 20 Nm. A dab of thread-locker (loctite or equivalent) on the threads is recommended by many.
Super Moderator
http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm
![](http://i209.photobucket.com/albums/bb196/splintersAMG/M113frontcovertorque.jpg)
Thanks Splinter, I'm pretty sure that's it. At least it gives the bolt dimensions so that's an extra verification. I just saw a long bolt disappear back into the engine, didn't pay attention the pulley is on the water pump. That too is a check though. At this point it looks like 15 lb. ft. is correct. I probably won't use any loctite though since MB didn't. If it's needed, they use it. The casting supports the bearing and the bolt just keeps the inner race from turning. Thanks again.
Super Moderator
Fact is my various (C32) OE replacement pulleys’ mounting threads were coated with a blue substance of unknown origin.
Much like dealership-supplied chassis fasteners et al. Just saying. :)
I do have some 242 blue in the tool box, I suppose a drop couldn't hurt. I know it's the last time I'll have this bolt out. I put all of 1270 miles on my car this year. I just did an oil change before putting it away for the winter. Nine quarts of Mobil 1 with 1270 miles on it.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
When I was doing some work on my C43 - both the 4.3 and the 5.4 I have - I went with 20Nm. The bolt that holds the idler pulley in is very long, and goes through not just the water pump ("coolant pump"), but the timing case and into the block. I see the screen grabs show both 20 and 25 Nm. In the whole scheme of things, 5 Nm difference equates to not even 4 ft lbs. Heh, the $20 torque wrench you can get at any auto parts store probably has a 4 ft lb error!
What I'm interested to know is if there is enough clearance to get that bolt out without removing the rad. My understanding (though I never did it) is that the bolt is too long to be removed from a C43 without removing the rad. Money-one (with a 55K in his C43) had recommended doing the idler pulley with the engine out of the car (as part of a swap process) or pre-empting it by cutting off a bit of the bolt so as to enable it to be removed from the car without removing the rad. Just eyeballing it, I think there might be some more room between the engine and the rad on the C55 as opposed to the C43, but it's difficult to say until one tries to get the bolt out.
Phil - please update when you do the job!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
But that chart says 9 Nm for the pulley on the coolant pump. Splinters chart shows it being a 40 mm long bolt which is only about 1.5 inches and this bolt is 4-5 inches long which would be 100-125mm. Why is this so difficult????
BTW, anyone who says this bearing fails due to over tightening, hasn't had it apart. Can't happen, the bolt holds the inner hardened steel race ONLY and it is holding it against a cast aluminum fitting. The aluminum would react to the pressure long before the steel would. Not only that, holding the inner race is exactly how roller bearing on a motorcycle axle works and some of those have a tightening spec of over 100 lb. ft. of torque with zero effect on the bearing and some bikes don't have a bearing much bigger at all either.
I put my new idler and a new belt on last night just because it was so easy to do and inexpensive too. Odd, the idler which is the exact same made in Germany INA brand part still isn't 100% wobble free and it's brand new. Don't get me wrong, it's not all sloppy and falling all over the place, but if you grab it, you can feel a little movement. It's smooth as silk and doesn't feel like anything is wrong so I am going to leave it, but it still seems a bit odd to me.
