Desperately need sc bearing!!
Thanks members!
Rob.
I have not found any one else on this forum to use this bearing so I'm not sure how long it will last. I installed this bearing yesterday. it cost me $11 at autozone.
http://www.autozone.com/autozone/acc...ntifier=946310
Is there a spec sheet avail for the oem bearing? Rpm and lb. Los are a concern with the autozone.. However if they're acceptable (safe) to use that would be perfect for a temp replacement!!
I am located at fort Polk Louisiana. This autozone bearing is rated for 20000 rpm and 412 lbs. Name indicates a Japanese origin.
However, as I stated, it will be a couple Of weeks and I will install the oem... I'm afraid it's going to completely fail at any moment...
And again.. U guys are greatly appreciated!
