Crank Pulley replaced......what's wrong with this picture?
Old Jan 3, 2012 | 04:38 PM
Dasauto's Avatar
2003 C32
Car has 47K miles, crank pulley was original. Just replaced before any damage occurred but what a failure! The crank pulley had moved forward by almost 1/2" due to the rubber failure. Got lucky! Anyone every see a failure like this? I heard that most of the time they "walk in" and not out when this happens. Crazy.
Old Jan 3, 2012 | 06:54 PM
320 dreamer's Avatar
2003 porsche 996 turbo
my 32 crank pulley went out at 30k so you arent alone!
Old Jan 3, 2012 | 07:46 PM
430's Avatar
430
SLK32
I went through the stock crank pulley at ~25k miles then an ASP pulley (built off the stock pulley) after another ~18k miles.
Old Jan 3, 2012 | 08:54 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Does anyone know the durability of Eurocharge crank pullies? I know it doesn't have a harmonic dampener so should it last without failure? I'm amazed the stock crank would go out so quickly...
Old Jan 3, 2012 | 09:03 PM
they are dampened pulleys also
Old Jan 3, 2012 | 09:04 PM
430's Avatar
430
SLK32
The Eurocharged crank pulley is a balancer just a different style than stock. I have been running an early 185mm for longer than I ran the stock pulley and have not had any issues.
Old Jan 3, 2012 | 09:18 PM
gt4awd's Avatar
If Eurocharged could chime in with a estimation per mileage on durability and any warranty covering this type of wear that was help ease my mind...
Old Jan 3, 2012 | 10:55 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I have seen the oem pullies do that pretty often.
Our pulley is indeed internally dampened, always has been. We have customers with 70k on their pullies.
I personally had 60k hard miles on my 185 c32 when I had it...
