Helpppp Engine surge and no CEL!!!!
Last night in parking lot sat idling for 30 min or so. Then I feel a little shudder in the engine. I turn off the radio and the engine is at idle and surging!!!! no engine lights on at all. I go for drive and still the same.
Shifting how ever seems like its is not smooth and a little jerky like the tranny is shifting at the wrong points.
An am fairly mechanical so I think air fiters no they are clean. Then may be a stick TBS remove it and it is sealed but butter fly moves fine. reinstall and still the same. Disconnect the battery and still the same.
Helppppp please car is drivable but what is wrong it was awsome till I sat idleing what did i screw up hear??
Please any one
My gut say`s the throttle body.
I say this because my Yukon Denali had similar issues.
Rough ideling and poor shifting and since they are both electronically controlled transmission. The truck got a TPS sensor and the problem went away!!! I just dont want to throw money away!!
The car has no problems starting. and runs better cold 5-10 minutes later the surge!!! The Alternator is new 3 months ago and voltage is fine. As for vacume leak I do not hear any air hissing. Now where is the map sensor located as well as the CPS? what is the sensor under the TB near the tranny and engine connection? TPS ?
Thanks to all so far for this newbie in Ontario Canada
I googled the problem and searched the forums and it appears there are many fixes what is my best bet in reagrds to a repair?
TB?
pedal sensor?
Any adice please
I dont think so a few hours later and a few more erands to run, the surge returns if I shut off the car and restart it goes away. if I touch the gas the rmp climb then stay there when my foot is off the gass and then slowly comes down to lidle. No CEL right now. What do I do? buy the TPS or the TB? I know buy both!!! does anyone have a stock TB they can sell me from there conversion? what about a gas pedal???
A Throttle body is going to cost you waaaaay more than a gas pedal. PLus, if I was replacing it, I wouldn't trust a used throttle body, you could just end up having the same problems.
In the meantime, if your car is acting up, do a throttle body reset and that should at least get you on the road and running again temporarily.
Unplug the harness that connects to the throttle body. Wait for one minute and reconnect. Then go and turn the ignition to position two, you will hear the TB whirring. Wait one more minute, then start the car.
limp the car to MB dealer scan check now they say need TB $2200 plus tax.
F that TB is good I am told.
Limp the car home wait till the next morning and drive the car to Toronto for my garage Euromotion to repair.
Next day he calls me and says he has trouble shot the car and I need a ECU ( no voltage to TB)
He gets a used ECU from C240 and replace board level components and retries.........
no luck need ECU from C32
2 weeks later I get ECU from 02 SLK32 used from a bone yard he gets ECU reprogramned and installed and turn key and the bictch runs. He test it for awaile and performs a road test and warm restart.
I go to Pick up car 6 hours labour scan and enviro fees and ECU program with 13%tax $900
I pay and drive car home and feels good. Only problem is off the line the shift point are slow and the kick down seem non excistant any thoughts? Does this new ECU need to learn my habits? any thoughts before I call them tomorow.
The only thing that solved my problem is the Engine Wire Harness, as soon as it was changed signals to the TB was normal and all errors just disappeared even the ESP ones, been running really good lately, fingers crossed been a few month now.
shifts were lazy and it was not too smooth either.
quote=Solarman2005;5078417]Well team got my car back from my repair man. What a run around!!! First of all bought a fellow forum members used TB and gas pedal assy, install and test no luck!!!!
I pay and drive car home and feels good. Only problem is off the line the shift point are slow and the kick down seem non excistant any thoughts? Does this new ECU need to learn my habits? any thoughts before I call them tomorow.[/quote]
