Cold start, put to "D" shift then stall
Old Jan 26, 2012 | 09:21 AM
Wilsophia's Avatar
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
This morning is cold, around 6C at outside temperature. When I start the my C32, everything is ok and the engine idle is around 1000-1200rpm. It keep steady running. Then I put the shift to N, it still running smooth. After 1x second, I put it to "D" shift. The car just started to move but it stalled! The dash show up a "battery / alternator visit workshop". Then I turn off the car and restart again. Everything is ok. Then I wait around 1 minutes and shift to "D", it run smooth all over the day.
Should that be the engine oil, coolant, engine fluid temp is too low and I didn't did the full engine warm up and cause the stall?
Please advise ?
Old Jan 26, 2012 | 09:36 AM
AMGnut88's Avatar
1996 S420 2006 C55AMG 2002Mustang GT
no i dont think your oils,fluid would cause a stall. sounds more like a airflow/sensor problem
Old Jan 26, 2012 | 03:38 PM
Budget Baller's Avatar
2018 GLE350
Do you have a checking engine light? I'm wondering if the car has thrown any codes. That would greatly help. There are a number of things that can cause the car to stall out.
(Though I'm wondering if it could be your CPS sensor)
Old Jan 26, 2012 | 04:53 PM
mikekuriger's Avatar
2010 C63
that sounds like a MAF sensor problem.
Old Jan 26, 2012 | 05:36 PM
nladam12's Avatar
C55 AMG
I would first think it was an MAF sensor problem, but I have yet to see one produce the alternator failure screen! I would check up with the MAF, check the codes, then check the alternator/battery. Its deffinately an odd problem. Check the obvious, then let us know what shows up. Is this a constant problem? and were there any symtoms before this happened?
adam
Old Jan 26, 2012 | 06:24 PM
mkonei's Avatar
05 C55
IAC if they have them.
Old Jan 26, 2012 | 11:51 PM
msheredy's Avatar
MB
Another possible curprit could be the crankshaft sensor going bad. That would trip a CEL.
Old Jan 27, 2012 | 05:50 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
C32 doesn't have a MAF and a broken CPS doesn't go out when cold.
pull the codes and check throttle position sensor if it happens again.
Old Jan 27, 2012 | 12:21 PM
Wilsophia's Avatar
Problem "seems" fixed after......the throttle **** fully cleaned.
This is the China New Year that all the garage, sub-dealer are closed for at least one more week until next weekend. There is no parts for sale at this moment. WTF !!
I have some spare time in this morning so I want to locate the MAP sensor first for the later replacement. When I removed the Y-pipe, I found that the throttle **** inside was full of carbon dirt and keep oily. And there is no gap between the throttle **** and body after fully closed. The gap was jammed by those carbon stuff. So I started to clean them by WD-40 and cloth rub. After deep cleaning work the gap appeared again. Then I installed everything and use electrical contact cleaned to cleaned up the electrical plug too.
Then I start the car, warm up for 10 sec and put to "D" shift, it run without stall or even no weak RPM !!! Everything resume back to normal. Then I leave and test again again night (after my work). It is ok too ! Very good !
Hope I have solved the problem because it is not very cold today, just around 12-13C. I m afraid it will have the problem when it drop to 5-6C again !
I have post some pics for sharing
Attached Thumbnails Cold start, put to "D" shift then stall-dsc01008-copy.jpg   Cold start, put to "D" shift then stall-dsc01010-copy.jpg   Cold start, put to "D" shift then stall-dsc01015-copy.jpg   Cold start, put to "D" shift then stall-dsc01017-copy.jpg   Cold start, put to "D" shift then stall-dsc01018-copy.jpg
Old Jan 27, 2012 | 12:23 PM
Wilsophia's Avatar
Some more photo
Attached Thumbnails Cold start, put to "D" shift then stall-dsc01023-copy.jpg   Cold start, put to "D" shift then stall-dsc01024-copy.jpg   Cold start, put to "D" shift then stall-dsc01027-copy.jpg
Old Jan 27, 2012 | 01:12 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Good job fo being brave. And Happy New
Year!
Old Jan 27, 2012 | 01:46 PM
Wilsophia's Avatar
Thanks Lenin,
Btw, I didn't tried the high speed test, I dunno how it's work.
For what I did, will it hurt the TB?
