Gear won't change.. Plz help...
Old Feb 18, 2012 | 08:22 AM
C55atMAX's Avatar
C55
Exclamation Gear won't change.. Plz help...
I just changed tranny and diffrential fluid today.. and on my way home..
I notice gear wouldn't go any further than 3rd.. so i pulled over and
restart the engine and it went normal for a while then somehow those
gear button in (steering wheel) DIDN'T work.. also I've try to
switch driving MODE but that didn't work either
what could be the probleme guys??? I don't understand why this starts to
happen after i change tranny and diffrential fluid???
now gear won't go any higher than 2nd.... like stuck on 2nd..
oh yeah one more thing i've notice was.. when switching from P to D..
There's more jerk than normal.. like.. it KICKS HARDER..
I've tried to reset ECU but didn't work either...... PLEASE HELP!
Old Feb 18, 2012 | 09:12 AM
mgiannetto's Avatar
'06 C55, '14 Audi S4, '09 Range Rover Sport, '07 Lexus ES350,
Are you sure you refilled the trans with correct amount of fluid? Just a thought.
Old Feb 18, 2012 | 09:13 AM
C55atMAX's Avatar
C55
yeah i am pretty sure..
I didn't change it my self.. It was done by certified mercedes-benz shop..
Old Feb 18, 2012 | 09:17 AM
03MBC32's Avatar
2003 C32
As stated above, you should have the transmission oil level re-checked.
Old Feb 18, 2012 | 09:21 AM
C55atMAX's Avatar
C55
Thanx.. i'll check and will post again....
Old Feb 18, 2012 | 10:04 AM
AMGnut88's Avatar
1996 S420 2006 C55AMG 2002Mustang GT
well if they did the work id take it back to them and tell them to fix themselves
Old Feb 18, 2012 | 12:06 PM
mgiannetto's Avatar
Just spoke to a MB master tech (was having the breather boxes on top of my value covers re-sealed) and thought I'd ask him why you might be having this problem. He said if the trans fluid filter is not installed correctly or pop's off that could cause issues like you are describing. Perhaps the folks who did the service will have to drop the pan and have a look or at least have them run a diagnostic to see if the car is showing any codes.
Old Feb 19, 2012 | 11:43 PM
C55atMAX's Avatar
C55
They said that speed sensor that located inside of tranny gone bad....? Is it possible that they accidently damage speed sensor?? While they change tranny fluid?
Old Feb 20, 2012 | 08:44 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
possible but I would lean more toward not having enough trans fluid..
To measure correctly, the car has to be in D while measuring....most shops don't do that or know to do that...
Torque convertor holds a decent amount of fluid, and you could easily be a quart low while looking fine when the car is in P
Old Feb 20, 2012 | 02:51 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
P, not D! My factory shop manual DVD says to check ATF level with the dipstick in P.
Old Feb 20, 2012 | 03:12 PM
loungn14's Avatar
SPONSOR
its wrong or what you are looking at is incorrect...
I have done trans repairs myself many times...as well as done many rear main seals. The torque convertor holds a lot of fluid.. as well as had the same error when the shop did my trans job and was low on fluid...
https://mbworld.org/forums/w211-amg/...n-flush-2.html
Old Feb 20, 2012 | 03:38 PM
lkfoster's Avatar
It's your call but it's in the factory manual and I tend to believe factory engineers. That, and I won't do anything around a running engine in D.
Old Feb 21, 2012 | 09:09 AM
C55atMAX's Avatar
C55
Thanks for the input..
Diagnosis shown that speed sensor is bad so I had to pay extra $600 to replace those..
Now Car runs smoothly as normal... I hope it doesn't break no more..
and of course shop denies anything to do with it... and it just coincident that sensor went bad at same day that i changed tranny fluid??
I don't know there's no way to prove it..
Old Feb 21, 2012 | 12:26 PM
lizardjack's Avatar
Shelby GT500
Tranny oil level has to be checked wile the engine is running and selector MUST be in P position! WIS document also requires to use STAR diagnose to be able to monitor the ATF temperature as it has to 80 DGC (it is important)
