HOW TO: Transmission Flush
1) When I pried the clip out of the transmission fluid filler cap, I couldn't figure out how to get the rest of the clip out. I just used a small flathead screwdrive and pushed it through from top to bottom.
2) The drain plug on the oil pan is screwed in VERY tightly so I just did what kjlindgr did and removed the six torx screws holding the pan up (they need to be removed anyway) and drained it that way.
3) I used an old concrete trough as the base for the drain pan and lined it with plastic. When the oil pan was drained. I then lifted up on the plastic (to create a bag of sorts) and then poked a hole in the bag and let it drain into a bottle that I had that was marked in one litre markings up to 4 litres. I ended up with pretty close to 4 litres (I must admit, I made a little mess trying to be a smartass and thinking the pan would hold itself up without the screws.. it held about 5 seconds before she let go and I made a little mess, I had at least 3.5 litres in my bottle though). I then filled it with four litres of fluid.
4) I used the transmission cooling line that kjlindgr did in his post. I used the same marked bottle I did for the drain pan and had it setting on the ground and had the line empty directly in the bottle (the bottle was setting on a flat surface). I was in the car so I could not see this, but right at the 3 litre mark, instead of the fluid coming out at a nice and steady rate, my friend said it started gurgling and it ended up being exactly 3 litres both times). It seemed a tad longer than 10 seconds but I just was worried because I didn't want to screw my transmission...
5) I just did two flush/fill procedures using 3 litres. I ordered 12 litres just in case but I still have two litres for next time!
Now for a couple of questions... I purchased a transmission dipstick that is supposedly for my car (and looks very similar to the one shown in kjlindgr post). I couldn't get this to work. Always showed transmission fluid past the top of the black plastic. Even before I emptied any fluid... Afterward, since we used the tube to fill the transmission with fluid, we couldn't get a reliable measurement because of the amount of fluid in the line. Since we carefully measured what we took out (except for the very first part), I was happy with replacing with the exact same amount... Also, I was surprised at how clean my transmission fluid was. kjlindgr's fluid was definitely burnt and needing of replacing. Honestly, when I took off my pan and saw the color of the fluid, I debated about even doing the complete flush. Mine was still pretty red. Granted, it was a deeper red now, but no where close to as dirty/burnt as kjlindgr's was! This is with 41851 on the car. And the transmission fluid had NOT been changed previously, as the original black pin was on the transmission fluid cap. But, since I had the fluid, the time, the lift, and the help of a friend, I decided to go ahead and give it a shot.
I was going to replace the adapter plug (the thing on the front right [passenger's side] of the transmission that houses those wires) but I couldn't figure out how to do it. I got the very first black plastic cap off and the wires were exposed but I couldn't figure out how to get the wires out... For anyone that has done this, can you please let me know so I can do it the next time I am under my car (oil change and brake pads/rotors coming up in about 4,000 miles).
I also did my wiper blades and my serpentine belt (I replaced the supercharge belt when I did my oil change about 1,000 miles ago)...
For those of you that read my 211 AMG Service Sheet thread, I am still working on the document. I just haven't had much time to create the links. I may just upload the file and be done with it, as the files are clearly listed and easy to get to anyway...
nice writeup!
Remember, this is a TOOL...which means it's purpose is to NOT be left in the dipstick tube. I think they are purposely made long for this reason. The manual also makes reference to never leave it in the tube.
The markings on the dipstick indicate the min/max fluid level at hot temperatures (80*C or 180*F) and cold temperatures (25*C or 77*F). Use the corresponding marks accordingly.
For those with a Mercedes FSM, I feel I should come clean and mention that kinda lied just a little before I get called out on it.
The FSM says that the first fill after the drain should be 5 liters. I mentioned only 4. The reason for this is because they never once mention how much you'll drain...yet give all these warnings about damage to the transmission by running too much or too little fluid. I'm sure those were long-term operational warnings, but I figured I'd play it safe and just add what I took out. Do what you'd like, 4 or 5 and you should probably be just fine. You aren't running it for long anyway (a matter of seconds) so I honestly don't think it matters. Just make sure that the level in the end falls within the marks on the dipstick based on the temperature.
Be safe, be smart, and you won't have issues.
Car shifts fine but want to be sure its done right.
Can anyone else confirm this? Last step and my baby is back on the road after a week!
