Part numbers for differential bearings?
My installer thinks he may have alternatives...what that means I'm not sure, but if I get more info, I'll make sure to update you.
Bearings: 230 350 03 49
Seals: 230 997 03 46
Putting that part number in at getmercedesparts.com and at parts.com shows it fits a C55.
When I had MB install my Quaife the shop manager searched for quite a while and ended up saying the same thing that you guys heard, MB does not offer the bearings as a separate line item, only available with the complete rear end.
I haven't had any issues at all but if somehow you guys do find that they are available I'll certainly pick some up.
230 350 03 49 Bearing
230 350 02 49 Bearing
230 997 03 46 Seal X 2
I've got the carrier ready to go back in the case tomorrow. Getting the ring gear on the carrier was a PITA! I had to put the gear in a toaster oven for a while and the carrier in the freezer to get them together. Everything else has just been fiddly.
I also decided to replace both axle nuts: 001 990 38 50
A few things to note about the installation I didn't see elsewhere: The snap rings ARE the shims, so don't mix them up and make sure they get reinstalled on the same side the came from. The first snap ring (doesn't matter which side) will be tough to get out (and back in).
Model C180 Kompressor SE Blue Efficiency
Transmission Auto
Chassis No---WDD. 204-0452-A-326-228
Engine No---271-910-312-719-62
CC 1597.
Petrol
Germany. Manufactured 2009.
First reg 12-07-2011
Diff on the housing
A204-3507 400 237 360 2008
A 203-351-06 05
LE 8 GGG 40
Diff Pinion bearing
1.Outer NTN JAPAN LN ECO CR - 08 A 76.1
Inner NTN JAPAN LN ECO CR - 08 A 76.1
2. Outer. NTN JAPAN ML ECO CR - 06 A 75.1
Inner NTN JAPAN ML ECO CR - 06 A 75.1
Diff Counter Wheel Bearing
3. Outer. NTN JAPAN LN ECO CR - 10 A 22.1
Inner. NTN JAPAN LN ECO CR - 10 A 22.2
4. Diff Counter Wheel Bearing
Outer. NTN JAPAN LL ECO CR - 10 A 21.1
Inner. NTN JAPAN LN ECO CR - 10 A. 21.1
5. Diff axel oil seals benz CFW 2 45 - 85.3. -8/14 211 007 01 48.
6. Diff axel oil seals benz CFW 2 45 - 85.3. -8/14 211 007 01 48 (same as no 5.)
7. Diff pinion oil seals benz CFW 4 40 - 70 /76 - 11/ 13.5
025 997 00 47
