Need a piston C32 AMG
LET TUNE. CODE3 supercharger pulley. crank shaft 178mm pulley SL 55 air intake, stock place KN filters. NEEDSWINGS isolation kit, performance spark plugs.
The stacked pulleys gives about the same ratio as 185. You don't need to mess with injectors when you run 185 don' u?
It could be the pump or the filter. You have to check the fuel pressure under full throttle/max rpm.
When check AFR, it also could be a bad tune.
is this the same piston that is burned twice, if yes you have a clogged injector, also check the fuel pressure. where do you live? do you make high speed runs four and fifth gear?
And yes, he does hi speed runs. Usually sprints on highways.
Is the hi speed run a problem for C32? I've already seen it twice, the same failure under same condition. Exhaust valve in a 1st cylinder is bent due to camshaft failure, happens if you drive 250km/h for few minutes.
I cannot recall if that was the 1st cylinder on Rasim's car last time though.
He's got a logger but not connected it yet. Too late now(((
tuning technology motorsports fixed the issue by equalizing the fuel pressure with a looped rail and adding 550cc injectors then add a proper tune to scale the injectors.
i have this and my buddy has this setup on a stacked pulley car. if you put a fuel pressure sensor at the end of the oem rail you will see 60 psi max fuel pressure. loop the rail so the flow is equalized and the pressure drops to 55 psi. this what happens to the back cylinders as pressure is built at the front then moves back.
i have been testing this for ttm for about 4 months or so. final rail is done and injectors flow more than enough fuel. scaling of the injectors is done and the car runs like oem for idle and cruising. tuning continues to now bring the power out of the setup.
Conclusion - if the pressure drops at wot = the pump cannot cup.
Just imagine, injectors are (almost) continuously open at wot which makes the pressure to drop. Now if the bigger injector installed the pressure should drop even lower. Ok, maybe there will be enough fuel but will it be properly atomized?
I believe the "bigger" pump is the way to go.
this has been proven on both the e55 forum and the crossfire forum
the pressure drop isnt from the inability of the pump to keep up but rather a false sense of pressure because it builds from the end of the rail backwards. loop it and the pressure is a more accurate representation of what the pump is flowing.
my friend is running a stacked setup (181 crank w/ a 69mm s/c pulley ) logging 22 psi and no lean issues at this time. when he initially had the sl55 fuel pump the 181 was fine but went lean with the stacked setup. add the 550cc injectors and he went pig rich 10 afr. scaled properly his afr is safe thru the rpm range
http://i599.photobucket.com/albums/t...8/7a7409cf.jpg
