3rd to 4rd gear shift, hard fuel cut?
Any help would be appreciated. Thanks.
Bry
I'm so bothered by this issue, I'm actually considering going back to the stock pulley. To me power is nothing without drivability. Granted, I don't get to do pulls too often that require WOT 3rd to 4th gear shifts, but still. I was going to ask if the TCU tune will fix this issue, but reading the reply above, seems like it makes it worse? Does anyone see any problem with trying out the stock ECU shift pattern? Will that infact burn out my clutches?
thanks.
U tune but it is gone since I went back to the stock TCU. Post your DashDaq log. Maybe something could be learned from it.
im running a stacked setup with a c3 s/c pulley and a pte 178mm fluidamper crank pulley. pulled 22 lbs boost at wot
the issue originally reared its head only with the esp on. with the esp off it would shift fine. during the dyno run it would happen at part throttle with the esp off.
It takes a while before it adapts back, and before that you can
feel a jerk between shifts at full power; it cuts and then it comes on.
thanks guys.
thanks guys.
Steve, who is the new tuner?
Bry
BTW I have added a SL55 intake kit since the EC tune 8months ago if that makes a major difference however am pretty sure it would do it on occasion beforehand.
