ANY TIPS For Fitting Johnson I/C Pump?
im going to tackle fitting the new Johnson intercooler pump this week...
any tips for fitting?
i know the wiring is different - but does it matter which way round you connect the wires?
also does the outlets need to be at a certain angle to help bleeding the system etc?
Cheers
Try to position the pump a vertical as possible so that the brushes of the motor will not wear off quickly. ---->i read a DIY on how to rebuild them and said one of the main causes was the worn out brushes of the motor b/c of it's horizontal position. I was able to manipulate mine into a 60 degree angle.
Lastly a six pack of your favorite Brew
.GL,
John
As for the wiring I take it I just cut off the original connector and replace with spade terminals?
Is there a certain way the wiring goes on?.....I mean I don't want the pump to be working in reverse lol
Cheers
is it as simple as joining black to black and red to red?
cheers
