Boost Cut/Fuel Cut during extended high speed full throttle!
Sometimes during a decent high speed stretch with full throttle on/off 100mph+
I am getting as I can only describe as boost/fuel cut
The car just cuts power as if supercharger switching off
Sometimes the power comes back on - sometimes I need to stop and restart car and is back to normal again
It is the same symptom as Japanese turbo cars when you turn up the turbo boost and the ecu cuts the power so you need a fuel/boost cut defender to overcome this.
No faults on star
I fitted a new Johnson ic pump yesterday but it still did the problem last night.
The weather has been quite mild so is there a cut off if the air intake temps get too high or could the intake temp sensor be not right.
My car deff feels more lively with the new ic pump fitted.
Cheers
The only other modification I have done is the later spec grille which has larger openings so I can't see that causing a issue.
Cheers
I used hose clamps so I only lost the amount of coolant in the pump.
I just topped up the resovior.
Is there a special procedure fr bleeding system properly?
Cheers
i found this - P2027 Intake air temperature too high/Check coolant pump& additional radiator
so looks like i need to check if intercooler pump is actually working...(NEW PUMP FITTED LASTNIGHT)
does the pump run constantly with engine at idle?
im in Scotland UK.
i fitted the new pump lastnight as i was hoping that would be the problem.
im sure i can log the data with the snap-on solus.
ill try that tonight.
i just want to double check that the new pump is running when it should....
ive searched loads.....
so when car is stationary and bring idle up to 2000rpm this should activate the pump yeah?
and keep running until engine is switched off?
CHEERS
Start the car with the reservoir cap off and allow to idle until the thermostat opens. The coolant level should drop when the thermostat opens - air is escaping. Add more fluid slowly. Close the cap. Rev the engine to 3000rpm for 20 sec. Retudn to idle for 1 min. Let the car cool down and do the whole thing again one more time from the begining.
Found the problem!
fuse no5 in rear sam/fusebox was totally missing!
i got a new rear sam fitted a couple of months ago just when i got the car.
fitted the fuse and can hear the pump running now!
removed the fuse again and pump deff doesnt work!
so poor car was getting too hot!
HAPPY DAYS
I ordered the i/c isolation kit as its got to be a good thing.
Happydays
Indie pressure tested the IC and
must have left one of the NW taps on.
