removing cats. Hp gain?
on C55, deleting your secondaries is good for 5-10 whp/tq. On a C32, deleting the secondaries will add zero power and make your exhaust louder
for the primaries on a c32, you likely won't see very much gain from removing/switching to high flow primary cats UNLESS you have hearders since the stock exhaust manifolds are very restrictive and are the bottleneck. I don't recall the numbers for deleting/switching to high flow primaries on the C55 but i'm sure they're worth something
..... but the exhaust note it produces makes it all worth the $120 in labor and ss pipes
. now i'm debating on removing the resonators as well. so i'm on the
fence.
but if you love the sound, then clearly it was worth the money
