Urgent !!! Sl 55 to C55 Engine swap
Old Aug 11, 2012 | 09:10 PM
alfred dahdah's Avatar
w 203 c 55 amg
Exclamation Urgent !!! Sl 55 to C55 Engine swap
Hey guys,
I own a 2005 standard C55 AMG. I m looking to increase its power so I bought an SL 55 S/C engine to swap it. After finishing all the swap(ECU+Engine), I ran through an issue with the differential because the wiring is somehow different than what I have and the traction control is not working anymore. is there any possible way that can be fixed ? i ve been told that the SL55 has an SBS system or so and will not work when fitted in my car...i m really desperate I payed so much for the engine and the swap itself but i hate to drive it or leave it like that...
Any suggestion is highly appreciated
Alfred
Old Aug 11, 2012 | 10:04 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
why'd you do an entire engine swap rather than just take the s/c and accessories and airbox from the SL and just get it tuned...its the same engine
Old Aug 11, 2012 | 10:12 PM
w 203 c 55 amg
i m planning to go with a high boost but i dont want to open up the engine and change the pistons into forged ones...so i decided to swap the entire SL55 engine and start from there.
Old Aug 12, 2012 | 08:40 AM
MBfinatic's Avatar
e36 318i, 2004 sti
Its cheaper to do the swap than retrofit the sc on the n/a 55.. Sad to say
Old Aug 12, 2012 | 12:22 PM
w 203 c 55 amg
Bump
Old Aug 12, 2012 | 01:30 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
2003 C55???
Old Aug 12, 2012 | 01:34 PM
kustom2k1's Avatar
03SL55
Get in touch with needswings..He's done swaps in crossfires..only person that comes to mind that could help..good luck.
http://www.needswings.com/
Old Aug 12, 2012 | 03:37 PM
maverik259's Avatar
i find it hard to believe that buying an entire engine (what like $10-15k) and swapping it is less expensive than getting a used s/c for $800-1500 (i think one from an E55 is f/s right now for $1000)...
Old Aug 12, 2012 | 05:11 PM
Robert AMG's Avatar
Cls63 & C32
Originally Posted by alfred dahdah
Hey guys,
Alfred
i told you before how to do it!! it's very easy and not more than 1 week work and not costly, Joseph el Helou has all the parts you need in his garage, and i'll be with him for help, you have to swap the internal of your engine with 55K ones(pistons, cams, crank) then put the 55K Sc on the engine, we have all parts needed including Heat exchanger pump, 55K intake, injectors.......... just call him for price. and i guaranty for you no check engine, esp on, all electrical components 100% working, if not don't pay.
Old Aug 12, 2012 | 06:01 PM
MBfinatic's Avatar
e36 318i, 2004 sti
The only one in the U.S known to have done the sc swap from a e55 to a c55 said it cost him about 15k (mike aka hooleyboy). I asked him about all the instructions to make it happen on my old c55 and he stated he would much rather have done the motor swap. He said it would have cost 15k at least. Mike had about 30k in his c55 before the terrible accident.
Old Aug 14, 2012 | 07:07 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Check with Sunil at Motorwerks in Houston Tx
Old Aug 14, 2012 | 09:45 PM
maverik259's Avatar
ah I didn't realize they were different internals as well...i was always informed the the engines were the same...and if the internals are different then they are not at all the same regardless of what model number they slap on it! lol they're about as same in the way that they are both v8s and thats about it lol
