C55 wont crank/start
So I recently bought this c55 a few weeks ago. Got engine mounts/tranny mount, and trans fluid and filter/gasket replaced today.
I have noticed since I got the car that it has failed to start twice, where when you turn the key after accessory to start it does nothing. It also has had some hiccups starting that mimic a weak/low battery.
Well today it officially stopped starting. I dont get any cranking so I believe that rules out CPS. I swapped my new battery from my 04 clk55 into the c55 and no luck either. Only thing I can think of is bad starter ( solenoid ) or EIS/ SAM problem.
Anyone experience something like this? I have no idea if the starter goes out on this car if it will make no noise or anything when you turn the key to start. I have checked all my fuses and can hear the fuel pump operate.
I'm thinking starter as well. Was it easy to replace? I've done it on many other cars but not sure how easy it is on this one.
I found it tucked low under the right manifold. I read somewhere that you go underneath and pull the cats off and the exhaust.
I would be more likely interested in going from the top and taking the manifold off.
I can get a Bosch starter for 200$ and save myself 800 minus a new manifold gasket.
Anyone know if there would be an issue taking the manifold off and going that route?
