Newbie on board C55........problems
First day - car picked up - Audio CD is not working, the Sunroof can't 1 touch close, Alignment off, headlight washer not working, etc
First week - I changed the OEM audio to after market audio system installed by Future shop....Alignment and headlight washer was fix by the used car dealer.
Second week - Change flat badge hood emblem, change rear license plate light to LED, Wrap the roof to gross black, tinted window, K&N filter(SUCK) I tell you why later......., Interior CF wrap
Third week - Secondary cat and resonator deleted, sounds awsome!
, H&R springs lower, install window vent visor and roof spoiler. Four week - Oil change, Cabin filter change, Transmission oil and filter change (big money spend). Bought a set brand new Nokian snow tires
This week......problems arrive: One day morning, the car was shaking like crazy and it automatically die while I driving, lucky I am in front of traffic light, I put on N and restarted the car. I search on the website, TB need to be cleaned and idle learned again (because the oil from the K&N Filters) -FIXED.....2 days later, my driving SIDE HID went out(going to pick up a morimoto D2S light bulb tomorrow and scare after the installation, the headlight will flick or the ballast or ingiter will die since people are having problems with the HID headlight)......
And now I realize some noise coming out from the brake pedal while I step on the brake (Master cyclinder going to die?). Some noise when I turn the steering wheel (is it the steering pump getting worst? or I need steering oil change) and some clicking noise from the driver seat when I step on the gas or the brake pedal (can it be fix?) Wish this is not too long for you(MB members) to read. I hope someone can help me out. I spend too much money on this car recently and I hope all these problems can be fix without big money. I appreicate for your help. THANKS
PS pump is most likely your issue. Dying when driving? CEL come on? any codes?
Depending on the miles there is a list of things you should change.... just to be safe etc
Yeah....few oil changes need to be done soon like steering wheel, rear diff, brake, coolant...etc!
I read there is a manual reset for the sunroof right? Havn't try it out yet.
The best mod I did for my C55 was to buy a warranty.
Mine serves as my DD and has been very reliable, but the warranty to date has replaced front thrust arm bushings, front sway bar bushings, front crank seal leak, and tranny electrical connector leak when I was in for annual service this Summer. I'm presently at 44K miles.
The car was returned running as new and still drives as new. The service tab for all that work was about $1,800, my tab was the deductible. Having a warranty has made my ownership tenure much more enjoyable.
I've got that, I do the window reset after each battery pull and it still stays the same
