i searched! I swear!!! front speaker cover removal.. help!
a car that can't do the throttle reset.
How do I remove the front speaker cover? Would like to give that thing a serious cleaning. I searched the forum, and the only thread I found.. basically was a few guys emailing each other info.
I love you all. Help a noob out.
W203 slightly modified
Start by removing the clip held in by two T20 bolts. This clip is near the door lock. Then lift that part of the trim away till the first clip beneath it pops. Then work your way around till the all release. Dont pull agressively. Just go till you hear it pop.
just use a tooth pick or needle to clean it out...or if you have access to a air gun you can use that...
MBworld Guru
white and whiter
gotta remove the door panel.
I don't remember you can remove the cover however. if i remember right they were put together with plastic peg through the door panel holes and then melts shut like 91RS said.
