C55 primary cats---> Sport cats?
Has anyone replaced the primary cats with sport cats? If so, how much of a difference does it make? Im not too worried about the HP numbers im looking more towards sound and keeping the car "safe".
I already have my 2ndary cats and resonator deleted w/ a Eurocharged tune. Would love to hear from anyone input about this!
If you do primary sport cats, make sure you go to a competent fabrication shop that can TIG weld them, do not MIG weld primary cats, they will leak due to the excessive heat/pressure the primary cats have to endure.
Hope that helps
Hope that helps
If you want to go another route you can do high flow primary & secondary/resonator delete. that will extract the maximum HP out of the stock exhaust system without touching the headers at all. All combined thats probably good for 25HP without touching headers.
I have removed both primary secondary cats and resonator, got a 28hp increase and a much more responsive throttle response, also the acceleration at on top gear on the freeway is alot smother, the noise is great too, one down side tho is that after about a week the engine light came on, although this does not effect the drive or performance of the car. And for $75 spent to remove the cats 28hp is a huge gane thats more than fitting sports cats for less the price,
So if u dnt mind the engine light to be on then i suggest do it, bt keep your cats, if at a later stage u want to sell the car just have them put back. Unless u know some way of turning the engine light off.without putting the primary cats back
If u remove your primary cats and the engine light comes on to turn it off disconnect the battery, it will eventually come on again after a heavy rain, got something to do with the humidity in the air, just a short way of turning it off, u can get the cat sensors turned off indefinatly at a mb dealership.
You would enjoy it a lot more if you took them off, besides theres no negative drawbacks about doing such.
I've had experience with various imports exhaust, both NA and Turbo and fear that rasp and drone you get from the wrong combination. An AMG V8 can't possibly make unpleasant noises though!
I am hoping for something similar to the stock C63s as far as noise, and I think this will come close. Thanks for the recommendation!
If you remove the primary cats you will get the CEL. I'm not sure if you will pass smog with aftermarket primary cats and you DEFINITELY won't pass without cats...
How is that Eurocharged TCU tune working out for you?
