people with gold caliper disease...
Old Jul 25, 2003 | 12:55 PM
Bux's Avatar
Bux
G
Exclamation people with gold caliper disease...
did you take it back to benz dealer to have it repainted? what did the dealer say? and after repainting it tracked again will the same thing happen? any costs?
thanks
Old Jul 25, 2003 | 03:05 PM
lap's Avatar
lap
From: Great White North (the one with the crappy dollar)
2002 c32
leave it..
b/c this way if I ever pull up alongside you I can identify if:
a) I have to "RUN" you or
b) "run" you
Old Jul 25, 2003 | 05:23 PM
Bux's Avatar
Bux
G
i don't have it yet but want to attend texas world speedway but the gold caliper is holding me back
Old Jul 25, 2003 | 05:28 PM
lap's Avatar
lap
2002 c32
i thought
I read somewhere that others did not have the "goldening" effect b/c they used a "racing" type brake fluid.... you may want to consider that option
Old Jul 25, 2003 | 05:40 PM
Mach430's Avatar
Gold is more valuable than silver. Go for it!!!
Old Jul 26, 2003 | 07:25 AM
Steve Clark's Avatar
C32AMG
Brake fluid type
has zero effect on the heat generated by braking.The brake parts get just as hot;better quality/fresher brake fluid will let your brakes perform better at higher,sustained temps.This will make the calipers'paint darken a bit more quickly.I'll take darkened paint over brake-fade any day.
Old Jul 26, 2003 | 09:48 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
do what you desire, man....don't let the gold caliper hold you back. Just go to the dealership and argue to change it under warranty if it changes color.
Old Jul 26, 2003 | 10:05 PM
Bux's Avatar
Bux
G
then in addition to extreme braking they are going to say "your tires are raped sooo abuse means buhbye to your warranty"
get on AIM
Old Jul 28, 2003 | 02:05 AM
BrabusCClass's Avatar
GL450, Sienna SE
Does anyone have a pic of this? Im curious how "gold" it gets.
Old Jun 10, 2004 | 02:20 PM
Sleestack's Avatar
My fronts are gold!!!! I am replacing them... nothing wrong with them, but gold just doesn't go with silver.
Can't post the pic... anyone want to host it?
Old Jun 10, 2004 | 02:45 PM
I1 ULOOZ
Guest
Posts: n/a
I would like to see a pic of that!
Old Jun 10, 2004 | 02:46 PM
MBAMGPWR's Avatar
W215 CL600
How many miles are on your car when it turned gold?
Old Jun 10, 2004 | 02:47 PM
Bux's Avatar
Bux
G
whoa old post!! ....hahahaha MBAMGPWR...it's not because of miles it's because of extreme braking at the track!
Old Jun 10, 2004 | 03:03 PM
MBAMGPWR's Avatar
W215 CL600
Holy crap! I didn't even notice how old the original post was. I just responded to a post that someone made today!
Old Jun 10, 2004 | 03:27 PM
SFoRZA's Avatar
C32 AMG 2002
If it went from silver to gold, it must be platinum by now!
Old Jun 10, 2004 | 04:45 PM
Sleestack's Avatar
I just bought the 2003 C32 used w/ 8,000 miles. I had it delivered to Evosport. When it arrived, Mr. Vanos noticed the gold calipers. I did a search and found a few threads, including this one. It is weird, b/c there are no other signs of hard driving. Oh well. They really are gold... it's pretty funny. I don't have a place to host the pic.
Old Jun 10, 2004 | 05:04 PM
Bux's Avatar
Bux
G
someone most probably auto-x'ed it
Old Jun 10, 2004 | 05:09 PM
Sleestack's Avatar
If they did, it seemed to have helped the engine... I don't have confirmation, but apparently it baseline dyno'ed at alittle over 300 RWHP. Not bad.
Old Jun 10, 2004 | 07:25 PM
Bux's Avatar
Bux
G
stock over 300hp? thats pretty crazy
Old Jun 10, 2004 | 07:43 PM
smgC32's Avatar
Some automotive metal paints become unstable at high temperatures and change color. It has to do with the quality of the paint used and its expected tolorance within its given use and environment. I wonder if the 8 piston caliper on the SL55 and E 55 will also change with intense heat? I don't think MB did heat testing on their caliper to see if a change in color would occur. It did not happened to my car, nor other C32's I have seen driven hard. Are all the gold calipers from 2002 model years? I would ask for them to be replaced under warranty. I don't believe it discloses this possible occurance in the manual.
Old Jun 10, 2004 | 09:15 PM
CynCarvin32's Avatar
Mercedes Benz
C SPot driving event or AMG challenge car? The fun of buying a used car. I saw a car that was sold used by Fletcher Jones about at month ago and it had gold calipers. The cars used by the AMG challenge and the C Spot driving event (hot lap cars) are all sold as used demo cars with no designation as having been used for racing style driving. They change the tires, pads and rotors and the car looks like new once again. I bet they also change some suspension bushings and steering parts for extended racing does not do a chassis good (unlike the human body lol).
Most dealerships will cover the gold calipers as warranty work. Roozy, I drove my C32 to the point of terminal fade many times and they never changed color. I doubt the track will be that hard on brakes. If you do not lap for 1 hr straight with no break the car should be 100% fine. The cars used by C Spot and AMG Challege are beat on for the whole day so it is no wonder the brakes change color.
Good luck... and have fun!
Old Jun 10, 2004 | 10:00 PM
Sleestack's Avatar
It is possible that it was used for some sort of track event during the first 1000 miles. I'm almost positive that it wasn't driven hard at all from 1000- 7500 miles. In any case, the car seems to be fine and is getting a pretty thorough checkup with Evosport so I'm not concerned.
Old Jun 11, 2004 | 03:21 AM
Renn 208's Avatar
I was told that this took all of 30 min. to achieve. And it's a 2004 car.
Old Jun 11, 2004 | 03:23 AM
Sleestack's Avatar
Wow that's even more gold than mine. If someone had a gold C, it might be cool.
Old Jun 11, 2004 | 03:24 AM
Renn 208's Avatar
It's also probably driven harder than any other 203 out there.
