For those with eatons ( kleeman ) that want smaller pulleys, come inside.
2005 E55 AMG
These pulleys work perfectly and go down to 1.9" ( stock is 2.8" ). I just installed a 2.5" on my friends car with zero issues.
http://www.pulleyboys.com/store/prod...2&cat=9&page=1
Can't beat the price either.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
EDIT: let me clarify something. Apparently kleemann changed the pulley system on the eatons at some point and there are two types of pulleys. If you have a pulley with 4 small bolts then it won't work. This will only work with pulleys that have a single large nut in front.
I used pulleyboys before on a different car and all went ok as well. Be careful not to overspin the S/C
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Did your friend get a retune?
Did he check his A/F ratio on the dyno? Power numbers?
Was the install easy? What does it involve?
No, you didn't quite get it. When I meant overspin, I meant over the max of the supercharger, not the stock setup. The eaton I had before had a max of about 17,000 rpms, and after that you got way out of it's efficiency range. But more importantly was that you need to be careful at those rpms with bearings going loose, rotors crashing into your housing, and shavings of metal going into your intake duct and cylinders. Not to mention your broken supercharger.
2005 E55 AMG
Oh...yeah, I didn't read it that way. Sorry.
2005 E55 AMG
Install was super easy. The pulley is not pressed on so it was as easy and removing the belt, removing the nut and swapping the pulley. 20 minutes tops. The kleeman idler pulley was always slightly off alignment and the smaller pulley I installed doesn't have the EXACT offset as the oem one but it's close enough and I added a washer behind the kleeman idler to align it better. I romped on it more than 20 times today and had zero issues.
C63 507 AMG DA Car #19
I would data-log the following on a full throttle romp:
fuel pressure
boost
AFR
Mass Air Meter Voltage
You might have to reset adaptations with the new pulley. GL.
I'm curious to see what boost you are seeing now.
fuel pressure
boost
AFR
2005 E55 AMG
I've already logged AFR, MAF Voltage and fuel pressure. All is well.
2005 E55 AMG
Okay, let me clarify something. Apparently kleemann changed the pulley system on the eatons at some point and there are two types of pulleys. If you have a pulley like the one pictured above then it won't work.
Not a problem at all, contact pulley boys and tell them you want a custom pulley, they should be willing to make it. In fact, you should probably send them your pulley so they can take measurements to make your new one, then market it here on the forum as a new product. I'm surprised Kleemann doesn't make smaller pulleys themselves? That looks like an easy bolt on mod.
2016 Chevrolet SS, 2006 Cadillac STS-V
Kleemann told me I have the 2.6" pulley already, but I haven't measured to confirm. I was running 7PSI of boost before the headers and I haven't had it dynoed yet again to see if it went down any. I talked to Cory at Kleemann and he said I don't want to run any more boost than that because of the high compression (11.0:1) of the NA 5.5L. An E55 is only 9.0:1. I don't really know enough about boosting engines and compression ratios and all yet to know what will happen.
2005 E55 AMG
I'm running 14psi ( and running 20* of timing on 93 oct ) on my E55 and I can ( and will ) go higher.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I'm confused as to how the type of sc would make a difference in the amount of boost that can safely be run if it has to do with the compression of the engine. That might be my research project for the day.
If you had a totally awsome intercooler it wouldn't be an issue for the engine at all.... except if the supercharger fails due to too high rpm. Of course there is a very low limit to how much intercooling you can package into these engines. Of course higher efficiency is a much better way to go. Centrifugal best > twin screw > roots worst.
The difference for non-centrifugal s/c's is the rotors themselves. In an eaton/roots style, there are curved triangular-like lobes that interweave each other to "push" the air into the engine. In the screw type, there are male and female screws that interweave each other and compress the air between them before exiting into the engine. One is compressing by restriction in the engine, the other is compressing in itself.
2005 E55 AMG
You would generally see a lot of diminished return. A temperature sensor post intercooler would allow you to see if the intercooler can handle the heat as well.
As GT-ER said. When you raise the boost 1psi you get a certain increase in power to the wheels. As you get out of the efficiency of the supercharger the gains diminish. You might start off with 25whp gain per 1 psi increase up to 7psi. When you go from 9psi to 10psi for example it might go down as low as a 5whp gain. You want to stop well before this point or get another supercharger. This works for all types of supercharger and turbo's.
Are there centrifugal kits for these cars? You already have heaps of low down torque anyway and it would be so much easier to package a proper intercooler and they are often up to 99% efficient.
