hmmm..looks like C55 pistons aren't too tough after all.
2005 E55 AMG
After installing a 2.5" pulley on the kleeman setup and beating the living hell out of the car for a week ( litterally about 50 wot runs to 100+mph in one week ) the car began misfiring. Here are the compression results:
1 = 170
2 = 170
3 = 173
4 = 175
5 = 165
6 = 145
7 = 171
8 = 97
cyl 6 seems weak ( engine has 105k miles and ran nitrous before the supercharger ). Cyl 8 is toast however. Car ran fine though even after the damage. It's always number 8 isn't it.
Keep in mind, AF ratio was high 10's and timing was a ridiculously low 7-9* with 0* of timing retard due to knock up until 3rd gear where it would sometimes retard 1-2* or so in small bursts which isn't bad at all. I guess the engine was just tired.
1 = 170
2 = 170
3 = 173
4 = 175
5 = 165
6 = 145
7 = 171
8 = 97
W203 slightly modified
That's a bit like saying that if you hit your partner with a baseball bat a few times you can see how weak they are.
These engines are not designed for nitrous or for racing style performance 24x7. At least not without oxygen sensor deletion, straight through exhaust, high flow cat, and exhaust headers.
2005 E55 AMG
He has headers, straight dual exhaust with no cats. I also tried to play it as safe as possible and it still blew...ouch.
The Kleemann Eaton currently has a 2.5" pulley ( stock is 2.8"" ).
E55 Pistons and rods.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
2016 Chevrolet SS, 2006 Cadillac STS-V
Wow. That's crazy. I guess I should leave mine alone and be happy with it.
Are the heads different on the E55 or just the rods and pistons? It might be a good idea to go with forged pistons, especially if the car is still going to be driven that hard.
05 C55 AMG
Uh running a 10 A/F...why the heck would you do that? Too rich is not good. Sounds like you cracked a ring landing, i guess we will find out. In the future run in the mid 12s A/F.
If the timing was being retarded 1-2 degrees, 20%, that means you were getting a significant amount of knock. I don't know this ECU specifically but most of them use a basic algorithm. Example, 1-3 counts of knock = keep advancing timing, 4-6 counts of knock = keep timing where it is, 7+ counts of knock = start retarding.
You never hit full load in 1st and 2nd gear which is why you didn't see these signs until 3rd gear.
Are you tuning this on the fly? What software are you using?
05 C55 AMG
Too little timing is not good either as your EGTs will go through the roof.
What were your readings for:
EGTs
IDCs
Is cylinder 8 furthest from the feed on the rail?
Do you have a datalog that you can show us?
I really think that methanol is a must when running boost on these N/A engines and especially if you are going to beat the crap out of it and not use race gas.
EGTs
IDCs
2005 E55 AMG
EGTs
IDCs
EGTs
IDCs
High EGT's will kill in loooong pulls. IDC was below 80%.
Bosch ECU's are ULTRA sensitive and can retard well over 10* of timing if they have to. Even bone stock most of these vehicles can see 3-4* of timing retard easily. My previous GTI 1.8T ( similar bosch ECU ) ran with 5-6* of timing retard constantly in every gear and in 40K miles never blew anything with over 400whp.
Granted, seeing 0* across the board will be safer no doubt, but when the C55 broke it was in a short 2nd gear burst with 0* of retardation. Again, this is on a 105K mile engine that saw lots of nitrous before seeing boost....maybe it was just time.
Keep in mind, the compression will be dropped from 11.1 to 9.0.
He's had no problems with the bigger injectors? Cory had told me something about a spot in the RPM range that wouldn't cooperate or something like that, which is why they now use the secondary fuel pump with stock injectors setup my kit uses.
Are you going to be doing the pistons yourself?
2005 E55 AMG
Yes, I'll likely be doing the piston install.
![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
Hmm, that's interesting. You might want to change that fuel system, might help the overall performance.
Any chance of maybe a how to how replacing the pistons and rods? Are you leaving the engine in the car or taking it out?
Wasn't Blackbenzz runing a stock bottom end in his 700+rwhp monster CLK? Makes me wonder if it was the nitrous...
Just out of curiousity, did you check the compresion when your friend was having the issues when he was still N/A?
With those lower timing i pray you don't have a melted piston or/and melted cylinder wall(do you know also what was AIT?) , the heads are little different the 55K has heads with higher volume, so with 55K pistons and rods you will have higher then 9:1 compression ratio, we don't how much higher cause there is no data available about heads volumes but i think below 10-9.5.
2005 E55 AMG
Never took compression before on this car.
7-9* of timing, while low, isn't exactly meltdown low and I never did any high speed pulls ( never went over 115mph ) so I doubt it was a big deal. Plus, the car still has 90+psi of compression and both plugs were fine when removed which means the damage shouldn't be THAT bad. Guess I'll find out.
after all it's time for 55k piston and rods.
05 C55 AMG
GT-ER, I have not tuned a car in a long time, 6-7 years. We used to tune a lot of mid 90's japanese turbo cars and aim for 12:0-12:3 A/Fs and maybe closer to redline high 11s. Is this rich tune due to the engine being N/A? I am not sure how that will affect it.
I am really curious to see what this piston looks like.
Did you do a leak down test? Maybe the issue is in the cylinder head...? Are these heads aluminium?
2005 E55 AMG
I didn't do a leakdown test since I figured I may as well go the extra mile regardless since removal of the cylinderhead is already complicated enough. May as well remove both along with the oil pan and do the whole thing. Even if it turns out to be a valve issue I'll still build a stronger engine.
They are made of aluminum.
Where were you reading your timing readings from? I just checked mine with a hand held universal scanner that shows live data, and it shows timing advance. I'm not an expert on what this should be yet though. Normally driving around it was -25* or so and under WO it was -7* the first time and -8* the second time. The MAP sensor was showing around 9 inches at idle which is about 4.4psi and at WOT it was around 25 inches which is about 12psi. Is that right? It can't be reading boost because there's no way there's boost at idle!
