HELP The New Guy!!!
I also have a ton of questions that I would like to clear up before i get the car. such as..
1.Im mixed up on if the car is reliable or not because everywhere i read its
ether they love it with no problems or they hate it and well never get a MB again..
2. I was going to get the EuroCharded stage 1 Power package kit .. good choice right when getting the car?? would you per fur something different..
3. Does taking the 2nd cats and resonators out make the car drown on the highway ?
4. I live in the NY area is there any performance shops around the area that someone could recommend for this car?
thanks for your time and feedback.
2 seat computers
entire fuel tank and sender
dashboard
front end rebuilt twice
motor mounts
transmission mounts
shifter linkage bushings
swaybar bushings
belt tensioner
supercharger pulley bearing
rear window shade
idler pulley
antenna amplifier
oil cooler seals
timing cover seal
valve cover gasket
power steering reservoir seals
rear tires ever 15k miles...
and a ton of other stuff that I probably forgot....
Currently the back shocks are bad and I am hunting ebay for a new steering rack. Yep, the rack is bad now.
Motor does run great and the tranny was just serviced and is good. Stupid thing is, I will probably keep it going. The car is a blast to drive. Just a tad maintenance intensive. I had a pulley on it for about 60k miles but took it off this summer.
Chuck
1. MB's are on the expensive side to maintain. My C32 has only had a few issues, but they get expensive if they begin to rack up quickly. Having a shop perform a PPI on the car you're looking at is you're best bet to avoid expensive repairs.
2. Eurocharged makes good stuff but there are alot of other options out there as well. Do your research before starting to mod the car.
3. No drone. In my opinion the car was still relatively quiet with the res and cats removed.
4. I live in Cali so im no help there. Hope you are fairing well through the storm.
