Karlos c32
Old Nov 12, 2012 | 07:48 PM
karlo.b's Avatar
2003 C32 AMG
UPDATES!
Been busy last couple of days.
Been studying for exams and such.
To update you guys
The KW v2 coilovers and Ghostriders Camber Kit are installed!
I am not pleased with the height my car is at right now.
I ordered:
20x Vorshlag 12x1.5x75mm stud conversion
2x H&R 10mm hub centric spacers
now we wait
Old Nov 12, 2012 | 09:11 PM
greekspec2's Avatar
2005 C55
Originally Posted by karlo.b
UPDATES!
To update you guys
I ordered:
now we wait
Old Nov 13, 2012 | 03:06 PM
karlo.b's Avatar
2003 C32 AMG
Oh i will also be throwing these on the car
Old Nov 13, 2012 | 05:36 PM
AMG3.2's Avatar
C63 AMG, P30
ooooh lightweight lugs?!
Old Nov 13, 2012 | 09:46 PM
karlo.b's Avatar
2003 C32 AMG
maybe
Old Nov 17, 2012 | 08:55 PM
greekspec2's Avatar
2005 C55
UPDATES!
To update you guys
I ordered:
now we wait
here's a few pics of mine with the shorter springs and I have an inch left of drop while tucking more than half of a 35series
Old Nov 17, 2012 | 09:58 PM
  #32
MBfinatic's Avatar
e36 318i, 2004 sti
Looking pretty tight in there!
Old Nov 17, 2012 | 10:02 PM
  #33
greekspec2's Avatar
2005 C55
4-5mm is all ya need
Old Nov 18, 2012 | 07:27 AM
  #34
Justsaymo01's Avatar
2002 C32 AMG
Just wondering how would you rate coilovers over stock amg springs, and lowering springs as far as ride quality.
Old Nov 19, 2012 | 12:36 AM
  #35
karlo.b's Avatar
2003 C32 AMG
yeah its weird how they designed it to be that close.
you should see mine... its probably 1mm from the sidewall of the tire.
you have pretty decent spacing...
you have to stretch your tires..
do you run winters or is it only a summer car?
i love these coilovers..
the ride is a night and day difference.
you can adjust them to be smooth at the low dampening setting.. mine were first at 8 fornt 7 rear. and it felt only a little stiffer then stock.
now i am at 12f/11r and feels much firmer and corners nicely. it does get a bit bouncy if your on a really bad road. but the roads where i am are pretty decent.
Old Nov 19, 2012 | 12:45 AM
  #36
greekspec2's Avatar
2005 C55
even with my stock C55 wheels and 225/40/10 Pirellis Pzero Rosso I'm at the same drop and require no spacers bout 3mm from perch
Old Nov 25, 2012 | 05:04 PM
  #37
karlo.b's Avatar
2003 C32 AMG
Some updates
I picked up a bunch of parts for the car
HnR 10mm Front Spacers
HnR 10mm Rear Spacers
Vorshlag stud conversion kit <3
some cheap lugnuts for winter
how my car sits with the kw coilovers/spacers/studconversion
Old Dec 3, 2012 | 05:01 PM
  #38
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
Perfect stance! Where would I find those bolts and nuts for the lug conversion?
Old Jun 13, 2013 | 04:08 AM
  #39
karlo.b's Avatar
2003 C32 AMG
which lugs are you referring to? the chrome ones? or the lightweight r40s?
The studs for the conversion are from Vorshlag. I ordered them from their site. I believe it was around 80 bucks.. Not bad. Since you can throw on any spacer from 2mm to 12mm
no need to have a bunch of different lug bolts.
Old Jun 24, 2013 | 03:14 PM
  #40
karlo.b's Avatar
2003 C32 AMG
So I ran into a problem.
I got a metal clinking? rubbing noise?
not sure how to explain in..
But it is coming from my passenger side suspension.
I also noticed the difference in ride height of this vehicle. Which I still do not understand.
so this is how she sits. the passenger side is a tad higher than that.
But behind the wheel its this story.
This is the passenger side....
This is the drivers....
Also.. Is my passenger side strut thing suppose to be lifted like this? because the drivers side isnt.
Any suggestions on where to order sway bar links for the front would be great. Or if there is an alternative.. sway bar with links? upgrade etc....
Old Jul 8, 2013 | 03:01 PM
  #41
karlo.b's Avatar
2003 C32 AMG
I read around the forum and noticed that a lot of people are getting the clinking noise problem from bad bushing/end-links.
So i ordered the front end-links and rear sway bar links.
Also ordered front bushings for the sway and 2 new strut mounts.
Going to be replacing all of those and hopefully it resolves the clinking noise and hopefully helps improve handling.
Old Sep 19, 2013 | 11:07 AM
  #42
karlo.b's Avatar
2003 C32 AMG
So i got a new camera and snapped some photos of the whip..
Still learning photography but hopefully i will get more good shots.
http://www.flickr.com/photos/101950046@N08/9765223124/http://www.flickr.com/photos/101950046@N08/9765223124/ by http://www.flickr.com/people/101950046@N08/, on Flickr
