ESP Limp Home Mode
2003 C32
ESP Limp Home Mode
This is my first post on MBWorld. I purchased my 2003 C32 last November. I love the car. Perfect blend of performance, handling and practicality. In March I experienced a ESP Warning and loss of power, which I learned Mercedes calls the "limp home mode". This problem has occured five times in three months, each time followed by a visit to the dealer. They have had the car for a total of 30 days. Everytime they said they could not find what was causing the ESP problem. Finally in June Mercedes agreed to replace the car. I now have a new C32. I cannot beleive it but the same ESP problem is happening with the new car. Once at 240 miles and now just this evening with 750 miles. I am driving down the road and all of a sudden the ESP warning is displayed on the screen and the car loses power and goes in the "limp home mode". After stoping turning the car off and restarting full power is restored. Has anyone else had this problem? What the heck is going on. I am off to the dealer tomorrow. I just got my car back from the dealer. They were able to duplicate the ESP warning but not the Limp Home Mode. Again they have told me they do not know what is causing the problem. Please respond if you have had similar problems with your C32.
Never had that problem with the C32, but I'm curious WHERE it's happening? Is it the same place or around the same area every time? Are any military installations nearby? You wouldn't believe what radar and other high powered transmissions can do to a car (at the airport my C32 key would NOT remote unlock the car depending on where I parked in the lot) and it's electronics.
MB C32 AMG
I have had this problem. The computer records the error codes. Have your dealed pull the codes. The dealer should report the codes to MB. MB just came up with a fix. My car has done this about 5 times in 56k miles of hard driving.
2003 C32
My ESP Limp Home Mode problem, has happened three times while driving past Tampa International Airport. My dealer does suspect some type of outside interference. And has asked me to keep record of locations of occurrences. The last three times and the two with my new C32, where far from any airport. They occur under normal driving, usually 30 to 50 mph. Well I have the car back now a week and no problems, I have my figures crossed.
I have the same problem
Same problem here. Strange it didnt happen with my 2002 (which had many other issues) but now happens with my 2003. Dealer has reproduced it and are in the process of ordering a new ME control unit but its on back order. Should be here soon so we'll see if that fixes the problem.
C32 AMG, CLK 320
MB advises the dealers to change the ECU and Throtle Valve Actuator. I'm not ready to change my Renntech programed ECU.
Here are the error codes:P2032
P207
P202E
P203B
P202S
P207
P202E
P203B
P202S
The codes reported at my visit were :
CODE P2001 COMPONENT N15/3 ETC CONTROL IS FAULTY
CODE 2312 CAN COMMUNICATION WITH THE ENGINE SYSTEM IS FAULTY OR ENGINE TEMPERATURE IS IMPLAUSIBLE
NO OTHER CODES FOR ME-SFI
2003 C32
Just Happened Again
Well I thought the last visit to the dealer finally fixed my ESP/Limp Home problems. It just happened again. With 2096 miles my 2003 C32 had its third ESP/Limp Home. This time I was accelerating after breaking. speed approximately 20 MPH. I pulled over turned the engine off and then restarted, and regain power. Well it's off to the dealer on Monday.
2003 C32
Hey AMGDood
You are lucky, having the dealer fix your ESP/Limp Home Mode problem with one try. It has taken the dealer eight tries and I still have the problem.
I have noted a few other C32 owners with similar problems. It does not seem wide spread, but my dealer after many calls to Germany still cannot find the answer.
I am at my wits end.
If you can please post what the dealer did to fix your car.
MB C32 AMG
This problem has me thinking of trading my car for a racecar. It has happend twice this past weekend. MB said that the fix is a new ECU and Throttle Body Accuator. My issue is that I don't have a stock ECU. I'm sure Renntech will work with my on this issue.
2003 C32
Twice in Six Days
It happened again. ESP/Limp Home Mode. Second time in six days and forth time with this C32. Yesterday I was driving about 50 mph, the ESP warning came on and the car went into the Limp Home Mode. I pulled over turned the car off and restarted to reset computer. Again I was out in the country. I think this puts to rest the idea airport radar is causing the problem. I have noted on this chat site, reports of similar problems with the SL55. It is my opinion MB has a glitch with thier AMG computers
I finally got my car back from the dealer after the ECU swap and was very hopeful the problem would be fixed. However, driving home that night the same problem happened again. The car will be back to the dealer this week - they have no idea what the problem is now and are in contact with MB. This is their last chance. This is nearly the end of the road for me with MB. Having already had 1 C32 lemon, its beginning to look like the 2nd one is headed that way too. Very, very disappointed and disillusioned with MB products. Love the C32 (thats why I gave it the chance with the second one) but I guess at some point I have to say enough is enough.
If, by some miracle the problem gets fixed this time , I'll let you know what they did to fix it.
