Another IC pump question
My thoughts are there's a relay somewhere that needs to be changed, but since there's no relay C in my 2004, what relay is for the IC pump circuit? The schematics lead me to believe it's relay P in the front (for circuit # 15), but I'm hoping someone knows for sure.
Anyone?
But with my slk32 my intercooler pump was fine and learned I had no fuse. Then the fuse the manual indicated worked but would blow after some time. Eventually found online about that bulletin.
The frustrating part is that MB tells me that the pump wasn't turning on, so I put a new one in and it turns on fine for a day. I didn't change any fuses, just the pump, and the problem came back. I wonder if there's a relay that was heating up somewhere and finally blew. I just don't know which one.
Does anyone have a wiring schematic for the charge air cooler circuit for a 2004 C32?
Also what I meant with my post was : lets just say fuse 18 is a 7.5amp fuse but mercedes had a bulletin to use 15amp instead.
Something like that happened for the fuse for the IC pump
Any other troubleshooting pointers would be greatly appreciated.
Now on to rest of troubleshooting, I refuse to accept steelership's diagnosis (P207C code) that the SC is bad and needs to be replaced. I would only change SC if I know what component is bad and can't be fixed or replaced, hence need for a new unit.
