Driver's seat Easy Entry/Exit Feature Not Working
Old Oct 2, 2020 | 12:00 AM
Mick1113's Avatar
2020 cla 250, 2017 Gle 350
Originally Posted by Amjed Kadhim
i have glc200 2020.
easy entry and exits used to work properly until two weeks ago when it just stopped woeking.
i tried the steps you listed but nothing happened.
if I reset the mbux system, could this work??
any suggestion?
I had the same issue. Never worked. Then when I got the update 080 on MBUX started to work perfectly.
Old Nov 13, 2020 | 05:44 PM
elmalo's Avatar
2015 S-550
The Easy/Exit adjustment range on my 2020 CLS 450 is so far forward so that it is totally useless, unless one has the seat all the way forward. Then it moves back a little. When the seat is where I have to have it to drive the car, it does not move the seat back at all for easy entry/exit. Would appreciate any suggestions to make it work.
Old Mar 1, 2021 | 12:32 PM
mseigno's Avatar
CL 500 (W216) 2012 & E500 (w211) 2002
Hello and thanks a lot for this procédure
Easy entry on my w211 2002 is full opérational now
Old Mar 7, 2021 | 11:12 PM
baris41's Avatar
w211 e350 4MATIC
This doesn't work for me, steering wheel col. works as it should, seats doesnt move though. ('07 W211 with memory seats). Any opinions?
Old Mar 7, 2021 | 11:41 PM
baris41's Avatar
w211 e350 4MATIC
Originally Posted by Lois Lane
IF NOTHING IS HAPPENING AT ALL, unplug the black plug under the seat with all the wires running to it and then plug it back in. It acts as a reset and your seat and steering wheel
will be working fine
Is this possible without retracting the seats? I couldn't reach the plug neither front or rear footrest.
Old Mar 8, 2021 | 10:26 PM
alb3rtt's Avatar
2002 C32 AMG (SOLD), 2004 C55 AMG
Pull the fuse for the seat module/door control for the affected side and it'll acheive the same result.
Old Mar 9, 2021 | 01:32 AM
  #32
baris41's Avatar
w211 e350 4MATIC
I assume both F33 and F34 ??
Old Jan 11, 2022 | 08:42 PM
  #33
Guvnor's Avatar
2019 c43
Thumbs up Driver's seat Easy Entry/Exit Feature Not Working
Worked for my 2019 C43 Thumbs up
Old Jan 12, 2022 | 04:13 AM
  #34
KAROZZA's Avatar
SL55 AMG/C180 K
I have found that if my seat driving position is far back, then entry/exit feature is lost on the seat back/forward motion(even after reset, it works just a couple of times) but the steering does move up/down always. It's as though the system feels there is no need for the seat feature due to it already being way back.
So, I have adjusted the steering/seat further forward for my comfort(as the steering was quite far out) & now the exit/entry convenience always works on seat & steering.
Hope this helps.
Old Feb 13, 2023 | 02:45 PM
  #35
mikegaan's Avatar
2004 SL55
Tried this solution, along with several others (2004 SL55). None worked. Finally came across a post suggesting replacing the key fob battery. Did that and bingo! Everything works again. Lesson learned: before trying all the solutions, next time I’m faced with this problem, first thing I’ll try is a new key fob battery (mine was pretty old).
Old Jun 20, 2023 | 01:50 AM
  #36
swiz's Avatar
2019 c43
Originally Posted by Arch Maichim
Mine is a glc 250d 2019 and it never worked. any suggestion?
How did you get it to work? I have the same model doesn’t seem to work for mine.
Old Jun 20, 2023 | 01:52 AM
  #37
swiz's Avatar
2019 c43
how did you get it to work I have the same model? It didn’t seem to reset or anything ?
Old Jul 30, 2023 | 08:26 AM
  #38
Dinkumww's Avatar
S350CDI Bluefficiency
Worked for me too
Originally Posted by ruben65
Randomly my easy entry/exit feature stopped working, my seat would not back up when key was removed, or move forward upon entry and key inserted, but steering wheel would either way.
Performing a seat computer reset worked for me and fixed my easy entry/exit issue. (2005 C55, been 3 weeks and working fine, so I wanted to share the process to reset it with everyone.)
Perform while outside vehicle with drivers door open:
1. Turn key to "ON" position 2 (right before start)
2. Press bottom seat cushion button forward, once seat reaches the full forward position, continue to hold for 10 seconds. Then release button. (I heard a reset click after 10 seconds, I assume meant it reset)
3. Hit seat memory button you have your settings set to and allow it to adjust to set position.
4. Get in car while seat is in your set driving position, close door, then turn key to off position and remove. (your seat and steering wheel should now adjust to the exit position setting)
Seat should now work with the easy entry/exit feature again.
For those that don't know about this feature their is a easy entry/exit convience setting you can turn on or off in the settings in the dash using the steering wheel menu control. See manual for how to turn on feature and set seat positions.
Thank you. This worked for me on second attempt on 2010 S350 CDI.
Old Nov 10, 2023 | 07:02 AM
  #39
joe03's Avatar
s205
how did you accomplish to do so?, I have tried on a 2020 S205 exactly as described and it did not work.
Please let me know how you did it.
Many thanks in advance!!
Old Nov 10, 2023 | 07:04 AM
  #40
joe03's Avatar
s205
It happens de same to me. I tried on a 2020 S205 and I cannot make it to work.
Did you finally get it to work somehow??
Please let me know.
Many thanks!
