Driver's seat Easy Entry/Exit Feature Not Working
Randomly my easy entry/exit feature stopped working, my seat would not back up when key was removed, or move forward upon entry and key inserted, but steering wheel would either way.
Performing a seat computer reset worked for me and fixed my easy entry/exit issue. (2005 C55, been 3 weeks and working fine, so I wanted to share the process to reset it with everyone.)
Perform while outside vehicle with drivers door open:
1. Turn key to "ON" position 2 (right before start)
2. Press bottom seat cushion button forward, once seat reaches the full forward position, continue to hold for 10 seconds. Then release button. (I heard a reset click after 10 seconds, I assume meant it reset)
3. Hit seat memory button you have your settings set to and allow it to adjust to set position.
4. Get in car while seat is in your set driving position, close door, then turn key to off position and remove. (your seat and steering wheel should now adjust to the exit position setting)
Seat should now work with the easy entry/exit feature again.
For those that don't know about this feature their is a easy entry/exit convience setting you can turn on or off in the settings in the dash using the steering wheel menu control. See manual for how to turn on feature and set seat positions.
The following 10 users liked this post by ruben65:
808C32AllMyGas (01-13-2022),
GreenDog (05-30-2020),
KAROZZA (01-20-2020),
madmark605 (04-18-2020),
Mick1113 (10-02-2020),
and 5 others liked this post.
CL65 AMG, CLK55 AMG, CLA45 AMG, 560SL, S550
Easy Exit/Entry
Thanks for the post. I have a different car (2005 CL65 AMG) but have the same problem you had. Exactly. I followed your instructions, exactly, but it doesn't want to reset after even 10/20/30 seconds of holding the seat forward button, then going through the rest of the motions.
thanks!
Hey this worked for me aswell!
Thank you so much!
My problem was as you described, but I also had problem with seat wouldet move forward or backwords by holding in seat memory buttons.
It all works now!
Car: 2007 CL500 rebuild as CL63 AMG (Everything exept engine).
Thank you so much!
It all works now!
2014 Dodge Ram Laramie crew cab
Well it worked on our Ram too. thanks so much. it was a real pain getting in and out without the seat moving. so maybe it is a Dodge thing? did it today, so hope it keeps working. but at least we know how to fix it now. Thanks
Unplug black plug under the seat...
IF NOTHING IS HAPPENING AT ALL, unplug the black plug under the seat with all the wires running to it and then plug it back in. It acts as a reset and your seat and steering wheel
will be working fine. tQUOTE=ruben65;5576545]Randomly my easy entry/exit feature stopped working, my seat would not back up when key was removed, or move forward upon entry and key inserted, but steering wheel would either way.
For those that don't know about this feature their is a easy entry/exit convience setting you can turn on or off in the settings in the dash using the steering wheel menu control. See manual for how to turn on feature and set seat positions.[/QUOTE]
One of those things I have turned off because I KNOW it will break eventually in an inconvenient manner. Steering tilt mechanism has a known weak spot, a plastic dog bone breaks and tilt stops working.
CaliBenzDriver (11-17-2021)
HELP
I have 2007 CL500 ,the easy entry exit stopped working, where the seat operates fine but steering does not come down, even if i try to push the stick down it will not. Is there any fuses or anything to check?
Worked like a charm on my 2003 E55! Thank you!
Yes, in the owners manual it gives the time. I hold it for 5 seconds. Then move the seat and check it goes back to where it was.
Marantz99 (06-18-2023)
Many thanks for sharing.
Thank you! It worked!
Amazing. I have a 2017 300C and the seat just stopped the easy entry and seat memory yesterday when I was cleaning the inside. I have tried at least a dozen different things and spent over 2 hours researching the issue. this was the LAST thing I was going to try before taking it to a dealer and wasting several hundred dollars I'm sure. Well, this WORKED. Thank you.
Unfortunately, although it did work on mine, it is not a permanent fix. I have to keep moving the seat slightly forward & then use memory position for it to work again, before it loses the convenience once again!
easy entry and exits used to work properly until two weeks ago when it just stopped woeking.
i tried the steps you listed but nothing happened.
if I reset the mbux system, could this work??
any suggestion?
