multifunction display replacement
c32 amg
Well I finally replaced the lcd in my c32 this weekend. The display quality had diminished to the point as to be unreadable even in cold weather. Im not a fan of the c32 instrument cluster as it gives you very little information. I ordered the lcd from minitools.mte.net on 3-13 and received the part on 3-18. Cost with shipping was 147.03 us to Virginia. Lisa Zotti is the US rep. The part # is SEPDISP06. Group buys will result in substantial savings. When you email them ,have them attach their "details request form". This will save you about a day as there is about a 6 hour time differential. The replacement works perfectly and can be installed in about an hour. No tools really need other than a bent coathanger to remove the cluster.
I wish I had done it sooner!!
Is there a write up on replacing this or is it pretty straight forward once you remove the cluster? Mines starting to go out on me so if its really only 150 ill go ahead and replace it.
