c32 amg late respond
hi guys need help my c32 amg gets late response any suggestions? delays is longer then it should be after hitting gas pedal. thank you
Intercooler pump on its way out?
Originally Posted by wawy
(Post 5604531)
Originally Posted by D Boi
(Post 5604519)
Exactly what I was going to say, reset the ECU.
i did it it feels little bit better thanks guys but not as good as should be :(
Its an expensive little thing but paid its self off in the first week for me: Sprintbooster?
https://mbworld.org/forums/c32-amg-c...ck-thread.html https://mbworld.org/forums/c32-amg-c...loads-fun.html https://mbworld.org/forums/c32-amg-c...ter-worth.html |
thank you so my next step's gonna be sprint booster
Do you inspect your tranny...??,
first, you have to check your TCU, if it had an oil inside it, or you may have a bad "Conductor plate" or bad "Solenoid switches", those things mostly causes that delay issues.... ZAYED,, |
Originally Posted by macbryanie
(Post 5606693)
https://mbworld.org/forums/c32-amg-c...ck-thread.html https://mbworld.org/forums/c32-amg-c...loads-fun.html https://mbworld.org/forums/c32-amg-c...ter-worth.html I like "Sprint Booster", gives a very sporty feeling & soo fun drive with it, but need to solve any issues before putting it..... ZAYED,, |
thanks zayed am gonna check it on monday do u think it could be sparks as well? and tranny is bit jerky too
If you have a bad spark plugs, you will forcing a "bad start emission & fuel consumption & Engine shaking & surge acc. pedal",
tranny jerking could be sign of "bad or less oil/clogged filter/oil in the TCU/bad speed in the conductor plate"..... ZAYED,, |
no they r not bad but it's platinium and it should be iridium as i know but they are new i bought by mistake so what am gonna do is check tranny first . thank you again for your reply
plus i changed tranny fluid about month ago is stealership
You welcome,,
Why they not change the Conductor plate...?, or check the solenoids....??, or check the pilot spacer if leaks...???, or see if oil reaches the TCU,, its soo important to check all these things while changing the oil .... ZAYED,, |
than they changed oil they changed filter too but am gonna check everything on monday and i'll give you answer thanks you
no pictures at this moment but am gonna put them up later on
so today i checked tranny and it seems like everything is good don't know what am gonna do
