wheels off centered??
I looked at my car from a distance directly behind it. Rear-right(side w/o fender rubbing) the fender looks noticeably wider than the tire. But rear-left (where rubbing occurs 99% of the time), the tire is exactly as wide as the fender's outter-most edge. When I asked my friends sitting in the trunk, it's quite obvious that the rear-right fender can clear the tire w/ minimal gap; but the rear-left fender touches the tire.
Do you guys have any insights on this? Is the off-centered rear wheel related to wheel installation (but I had the dealer check the wheel installation right after I changed wheels: lug torque, and tire pressure, etc)? Could it be the variation in tire/wheel sizes? Or could it be an initial factory issue (say that AMG just messed up on my particular C32's rear wheel alignment?)
Thanks.
refers to the drivers side, that is exactly where the rubbing on the rear occurs with my HRE's. The Passenger rear = ok.
So, it's not only me who have this problem. I measured my rear wheels, they were of equal width (I say w/ +- 5mm accuracy). So what did you do to rid the rubbing? I thought of stiffening the rear springs, but am afraid the ride is bone-shattering.
i.e // \\ , thus wheel travel will be more diagonal & "inboard" of the wheel well rather than "straighter" up-down towards the fender lip.
Yes this will work with your coilovers. You may have -1.0 deg in the rear at this time. If you change you rear camber to -1.5 this pull the top of the tire in a little. The rang of adjustment is about +or- 2.5 deg. Here is one of the toe bushings, the other 3 look the same. My brother have a beach house near you in VA Beach. I may be going there in a couple of weeks.
Dont take it to the dealer if they are 19s. they dont have the right program for that size. Find out who can do the best job and take it there.
You should not have a problem with it because c32 rear fenders come tucked in from factory so there's no need for further rolling of the fender...
i have 19X9.5 and the H&R cup kit and with 5 people in the car it still dosnt rub... even over bumps....
To my regret, I took my car to the dealer for the alignment a few days after I installed the wheels. I expressed the concerns regarding whether if they have the right tool for 19" aligning. They said they will take a look, and see; but they never took a look and did it anyways. I guess that explains why the rear is slightly mis-aligned, and why my steering wheel is not perfectly centered. I will for sure take my car to a wheel tire shop for the alignment again. Thanks for the insight.
Speaking of the off-centered steering wheel, do you guys know what could be the cause of that? It's about 5 degrees to the left. Doesn't affect driving but looks ghetto.
why does mine rub
