C32 amg EC 61mm pulley/tune before and after dyno #s!
Old May 15, 2013 | 02:25 PM
raf12690's Avatar
c32 amg
OK, so I finally had a chance to get my car out to the dyno where I did a baseline run earlier this year! At baseline I had PLM heat exchanger (no iso yet), res delete, green filters. A couple months ago I added EC 61mm pulley and had ECU remote tuned, I also added NS iso kit for heat exchanger. This is the same dynojet where baseline was done. I did however use dyno mode where before I couldn't figure out how to do it, and last time it took the guys 4 runs to get the right numbers. I didn't want the car getting too hot.
Anyways I thought this would give a good idea as to how the car performs w/ 61mm pulley!
Before 293hp/296 torque, after 344hp/349 torque. Both SAE #s. I'll add it was like 40 degrees out for baseline and 80 degrees today.
Attached Thumbnails C32 amg EC 61mm pulley/tune before and after dyno #s!-61mm-pulley-dyno-comp.jpg
Old May 15, 2013 | 02:26 PM
raf12690's Avatar
c32 amg
Next up for me is NW DCAI. I think the airflow restrictions on the stock intake are holding it back. Anyone have a used one for sale?
Old May 15, 2013 | 03:14 PM
raf12690's Avatar
c32 amg
Somehow conditions didn't get on graph. Here they are.
Attached Thumbnails C32 amg EC 61mm pulley/tune before and after dyno #s!-dyno-conditions.jpg
Old May 15, 2013 | 06:34 PM
macbryanie's Avatar
Porsche 2004 911
Cheers for the post, havent seen user data for the 61 till now.
The NW intake try : https://mbworld.org/forums/c32-amg-c...ey-1300-a.html
alternately: https://mbworld.org/forums/c32-amg-c...e-upgrade.html
Old May 16, 2013 | 02:20 PM
durableswedish's Avatar
2002 C32
+50Whp/Tq is pretty good. Any idea what kind of boost pressure the pulley overruns the supercharger? How has those parts changed your MPG versus the stock pulley? Any problems with belt rubbing?
Old May 16, 2013 | 03:46 PM
raf12690's Avatar
c32 amg
I think max is around 19psi haven't really done much data logging. I did have some trouble with belt slip at first and ripped through the first belt. Replaced it and it has been running great ever since. I also had to replace a faulty tensioner that had been weakened over time.
Still, If I kick down at like 50 into second gear I still get a slight squeak from belt, but runs great.
Not sure about the MPG change. I'm sure it's gone down with the way I've been driving it! Runs really smooth though.
Old May 16, 2013 | 06:52 PM
macbryanie's Avatar
Porsche 2004 911
Regarding the belt: a NW pulley saver kit (http://www.needswings.com/Pulley-Sav...c32178181.aspx) wraps it up better to prevent slip. Comes with a Gates belt. Previous to this I bought a Goodyear gatorback belt that looks the business but havent installed it as the Gates belt hasnt slipped with both the 65mm and 61mm.
http://www.goodyearep.com/productsdetail.aspx?id=3128
Old May 16, 2013 | 09:40 PM
raf12690's Avatar
c32 amg
You think the goodyear gatorback belt will hook up better than the stock micro-v? I'm just not sure I want the Pulley saver kit at the moment for such a minimal amount of slippage. Also should I go with a belt of slightly shorter length?
Old May 17, 2013 | 01:24 AM
macbryanie's Avatar
Porsche 2004 911
Not sure: would check with Eurocharged about the length but assume it would be the same. There are a few threads about the gatorback with positive feedback (E55 etc) but on this one : " https://mbworld.org/forums/c32-amg-c...tine-belt.html " not so great. I would very much trust Longn14's feedback and or any of the other high post count members as they have most likely been there already. The pulley kit is more so for the removal of the idler pulley then to provide more wrap.
Old May 17, 2013 | 12:33 PM
jahoo's Avatar
2002 C230 Coupe 1999 Mazda Miata
Did you replace the tensioner with the expensive C32 version or the cheaper NA version?
I have the 65mm pulley and Conti belt, seeing some slippage and a loose belt.
I've researched this a bit and can't tell what the difference between the two tensioners is, perhaps the C32 one is stronger?
Old May 17, 2013 | 06:34 PM
raf12690's Avatar
c32 amg
Got the oem one for the c32, but if i were to do it again i would just get needswings pulley saver kit, which I think comes with its own tensioner. Mine was shaking a lot and when i pulled it out it looked disgusting. I still get a slight slip here and there but it holds tension all the way through 100% when im not kicking down in automatic. When i kick to 1st or 2nd i still hear a slight sqweak. PSK is the way to go imo. Upgrade and spend the same amount. Im kicking myself right now.
Old May 20, 2013 | 11:13 AM
jahoo's Avatar
The PSK doesn't come with a tensioner, I asked Rob. Who makes the tensioner you got? I may go with an URO from Amazon and do the DIY belt wrap that is posted on the SRT forums.
Old May 20, 2013 | 12:26 PM
raf12690's Avatar
c32 amg
This is the one I bought. I think I got it for 220 shipped. I didn't want to change the tensioner, but I'm sure you could use others. The PSK for smaller supercharger pulleys comes with a tensioner pulley I'm pretty sure but not the whole belt tensioner assembly. I could be wrong. If you look at the picture it looks like they modify the tensioner.
http://www.new-part.com/product/merc...FYZaMgodiS4AGg
http://www.needswings.com/Pulley-Sav...gs-psk185.aspx
Old Apr 12, 2015 | 10:42 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
I am considering getting the PLM heat exchanger... was it a direct bolt on (no drilling / cutting) and easy install? Cooling improved?
thanks
Old Apr 13, 2015 | 04:45 AM
swedepat's Avatar
2011 C63 AMG, 589hp
I might be wrong.
but sometimes cooling will actually get less with faster waterflow.
Rgds
Old Apr 13, 2015 | 10:42 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
get the gatorback, it will help.
If you guys have any 32 questions let me know. I know the car all too well and what works/doesn't
Old Aug 6, 2015 | 04:44 AM
W203Society's Avatar
2002 C32 AMG
C32 Smaller Supercharger Pully.
Hey i want to buy a supercharger pully, but not sure were to get one and what to get. Also, how much horsepower does the C32 Actually make stock? I just Got a C32 2002 AMG so im new to this car.
Old Aug 6, 2015 | 05:14 PM
slomofo's Avatar
02 C32 AMG
It looks as if the 61mm pulley is no longer available. the 64.7mm pulley from Eurocharged is on my car and it made a HUGE difference. It'was the single most effective bolt on modification I have made.
Old Aug 6, 2015 | 05:17 PM
2002 C32 AMG
Were did you get the euro charged pully?
Old Aug 6, 2015 | 05:22 PM
slomofo's Avatar
02 C32 AMG
www.eurocharged.com
Old Feb 23, 2016 | 01:42 AM
Sickooli's Avatar
E250 cdi
thanks
Hi the plm h/e is a direct fit, i put one in my car , it helped the s/c from cutting out.
Old Feb 23, 2016 | 07:06 PM
tw2's Avatar
tw2
PLM is a fairly easy install. Should be a link in my signature from when i did it.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
