Help with s/c issue diagnosis (see photo)
All I want to know is whether the pulley is shot or whether this could all becaused by a bad bearing. Mind you, I've never had any prior indication that the bearing was on its way out. So could my mechanic be correct? Bare in mind, he's my dads best friend and isn't trying to f us over.
You get a little more power and it's much cheaper.
http://www.eurocharged.com/products/mercedes-tuning/c-class/c32/pulleys/eurocharged-c32-slk-amg-supercharger-pulley-detail
Our pulley was made to OEM specs...
You will get a new bearing with the new pulley.
Have a look at the pdf on this thread - pdf Code 3 Pulley install
https://mbworld.org/forums/c32-amg-c...ns-thread.html
Guy offered some help when you mentioned price. His post was more "responsive" than your pulley.
I was departing a car wash about 3/4 mi from home. No problems when I entered the car wash but after I came out, hit the accelerator to clean all the tire shiner crap that coats every inch of the lot. So a quick spin of the tires before pulling out on main road. Perhaps the quick change in temps caused the failure. I don't know. I do know, that by the time I reached the jug handle (New Jersey left turn), my coolant level was reading low. We are talking maybe 500 yds from point I excited the lot, spun tires, hit the jug handle. PS- plastic shroud was off motor as I had been servicing the engine earlier that day.
Link, can you take off the pulley and take some pictures?
I wouldn't be surprised if the aluminum conduit from the secondary air injection pump system came free from the rubber coupler and made contact with the SC pulley. There is a natural stress on the left secondary air injection conduit to deviate towards the supercharger.
The reason I think this may be a possibility is because first, your rubber coupler looks cracked and aged, and second, it doesn't take a lot for that aluminum conduit to be pulled out of the rubber coupling. Were you pressure washing your car?
I'm glad your motor is most likely fine though!
Purchasing everything new from the dealer will cost a lot, no doubt. If you have another car to drive in the meantime, you could put a WTB ad on this forum and the X-fire forum and pick up a used one from somebody who has upgraded theirs.
